Question about Dryers
Clothes get dry but leave them very wrinkled - Dryers
  • 715 Answers
Try using good fabric and reduce the heat
Posted on Oct 07, 2009
4 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: Maytag electric dryer model # MDE2500AYW
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
Here are some common solutions to help resolve the issue with your appliance:
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
SOURCE: twisted sheets
dry your sheets separately.
Posted on Nov 05, 2008
  • 1144 Answers
SOURCE: Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Posted on Jun 07, 2010
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
We purchased a Crosley Top loading high capacity washer several months ago. Why are ALL the clothes, regardless of fiber content, wrinkled when they come out of the washer? It does not matter the size
That's a normal result of the spin cycle which wrings the excess moisture out of the fabrics. The wrinkles should disappear, or be significantly reduced, after running them through a clothes dryer, or hanging them properly for line drying.
However, more wrinkles will remain if you allow the damp clothes to remain in the washer too long before drying.
Jan 02, 2015 | Crosley Washing Machines
How can I get less wrinkles in my clothes after wash cycle is finished?
I use the dryer to get the wrinkles out. If i have a wrinkled shirt that is already dry and I need to wear it, I put it in the dryer for a few minutes with a wet wash rag.
Oct 10, 2014 | Kenmore Washing Machines
How to remove wrinkles from polyester table cloth?
After unfolding a new tablecloth, you'll quickly notice those pesky creases. Even after washing and drying the tablecloth, they may still be there and with wrinkles too. Before you iron a polyester tablecloth -- which if done incorrectly may burn, melt, stain or shrink the fabric -- try rewashing and drying it in a manner that reduces wrinkles and helps get rid of creases. Then, iron only if necessary.
Read more : http://www.ehow.com/how_10054670_creases-out-polyester-tablecloth.html
Jun 23, 2014 | Furniture
Wrinkled clothes
My wife, who runs "dryer central", stops the dryer short of complete drying and hangs the clothes that are easily wrinkled.
You may also have the heat set too high, or the time set too long, causing the problem.
Try experimenting.
Be blessed.
Nov 05, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Clothes come out bunched together and wrinkled
Make sure that you take them out very soon after they are dry. Leaving them to sit in the dryer will cause them to bunch together and be wrinkled
May 08, 2012 | Maytag Dryers
I just got this HE dryer and the cloths aren't dry when the buzzer goes off. And the permanent press clothes are wrinkled... HELP! Plus it took almost 3 hours to dry sheets
It could have a faulty thermostat which shuts down to fast in drying mode, be sure and check that the vent is clear and not obstructed at all, thats the only way moisture has to leave the machine and dry the clothes
Jun 17, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Twisted sheets
Oct 28, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
