Question about Motorola Mobility RAZR V3
My phone is 6 days old and the keypad has frozen
  • dcm19661 Oct 08, 2009
    Still nothing. Thanks anyway.
    Can't. Thanks anyway.
  • 715 Answers
Return it quick
Posted on Oct 07, 2009
    President:
  • 2,976 Answers
Press & hold the # button. When it asks for your unlock code, either enter your security code, if you set one, or the last 4 digits of your phone number.
Posted on Oct 08, 2009
Dial button
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Dec 02, 2012 | LG enV Touch VX11000 Cell Phone
My nokia 5130 is frozen i cant seem to read my massages or pick up my calls since the keypad isnt responding
Good day, Try to turn off your phone, and open it after a few minutes. Its always the problem of NOKIA 5130. tHANKS
Sep 09, 2011 | Nokia 5310 Cellular Phone
Keypad frozen
my iphone keypad is not working. i can't make a phone call. please help!!!!
Nov 12, 2008 | Apple iPhone Smartphone
G600 keypad not working
Take your phone to your local market & ask any market phone repair vendor to fit a new keepad membrane, if this doesn't work it's trobably irriparable damage either caused by water or the fumes of some kind of solvent for example super glue.
Nov 12, 2008 | Samsung SGH-G600 Cellular Phone
Motorola Q9m frozen how can I get my contacts
I can't tell you how many times this phone has frozen, and unless you've been using a sync program, you're out of luck.
You can do a hard reset, which resets the phone to factory settings by removing the battery to shut down, then put the battery back in. Hold down the middle key on the silver directional pad while powering on. It takes 5-10 seconds but you will see the "Master Reset" option on your screen, follow the directions.
This happened all the time until I went to the Motorola site and did full phone update ( http://direct.motorola.com/hellomoto/Motosupport/source/SoftwareUpdateSelect.asp?country=USA&language=ENS ) Now my Q9m which used to freeze 1-2 times per month hasn't frozen in 6 months - good luck!
Oct 17, 2008 | Motorola Mobility Q9m Smartphone
Sanyo MM-8300: ALL the keypads are frozen and won't work. Any solutions?
One thing you could test for is a thermal-fault in the phone's circuitry. To do this, you put your phone in the fridge over-night then, turn it on the next day and try the keypads while it's still cold from the fridge. If that doesn't help and you're brave enough to venture into the inner-workings of your phone to attempt repair/cleaning, you can read my post here- keys won't work on sanyo mm 8300 phone.
Hope this helps, TechnoWolfy.
Apr 20, 2008 | Sanyo MM-8300
Sprint Katana phone kepad frozen
I have the same problem. Has anyone figured out how 2 fix it????
Mar 22, 2008 | Sanyo Katana SCP-6600 Cellular Phone
W850i
In same condition i have same handset ,,,,,,,,,,,,, I flash it........ with Cruiser............. Means i completely remove its software and then install its software again........ then it's ok......... after some days it create the same prob then i change its keypad plate (upper keypad plate) in which display is connected 100% solution ..............
Oct 26, 2007 | Sony Ericsson W850i Cellular Phone
Keypad is frozen, cant dial out or recieve any calls
PSYCHMAJOR - take the phone back
guest - replace the flexcable
Sep 21, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Frozen keypad
The first thing to do is remove the battery for about two minutes, then put it back in and try it, most likely it will work just like new! If not does the phone have any history of liquid damage? Even a small amount of water, juice, pop, beer etc., can damage a cell phone however if you gently dry it out with the battery removed and without charging it by placing it about ten inches above a baseboard heater for a day or two, with it folded open, like you were on a call, it can often solve the problem. Good luck!
Aug 22, 2007 | Sanyo SCP-3100 Cellular Phone
Motorola Mobility RAZR V3 Logo
60 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
