Question about Royal Office Equipment & Supplies
The ribbon wont advance
I have a 1927 model royal portable typewriter and the ribbon suddenly wont advance. the spools aren't catching or moving at all.
    Champion:
  • 204 Answers
The ribbon drive on this model are gear driven..a .may be off, a loose set screw on one of the gears..the ribbon may be the wrong one or it has a ribbon reverse lever on the side of the machine, this should be free of binds.
Hope this helps........
Squipps
Posted on Oct 08, 2009
Bobber on 1937 royal quiet typewriter does not go up and down to catch ink on spool. I can manually move it, seems like the piece is not catching on the undercarriage
make sure the ribbon selector lever is in the black position not white if that is not the trouble you may ned a repair person
Dec 27, 2017 | Royal Office Equipment & Supplies
My vintage Royal manual ribbon cartridge does not advance when typing., stuck in same position.
Usually lubriction, there are small pawls or teeth that move gears and pegs that fit into the ribbon. make sure you have the correct ribbon.
Oct 07, 2014 | Royal Office Equipment & Supplies
Ribbon will not advance
Sir/Madam, I'm very sorry; this"fixya.com" assumes I have the knowledge to offer advice on typewriters but I normally need advice myself. Regret I can't help, Sincerely, Edwin Thoma, USN-Ret.
Sep 05, 2014 | Underwood 1957 Leader Turquoise Portable...
What kind of ribbon does a Royal Ensign typewriter take?
This was made in Holland so it probably takes a DIN spool they are no longer made you you may be able to use a universal spool.
DickyO
Aug 01, 2011 | Royal Office Equipment & Supplies
I have a circa 1940's-50's Royal Desktop Typewriter. The ribbon that was already on it was rather worn and severely faded so I bought new ribbon for it. The only available ribbon was a red-black silk inked...
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
Oct 16, 2010 | Royal MS 25 Typewriter
The keys on the left side of my circa 1933 Royal typewriter gets stuck on the ribbon everytime. Also my ribbon doesn't advance. Help?!
Hi:
The most likely problem is there is dirt inside the ribbon basket. This is the area where the type bar (this is the bar with the actual letter on it) ends. They all fit into a semi circle area. If you can find something very narrow and thin with a hook on it you can use it to clean out the areas where each type bar goes. Then try to lightly lube the entire basket right where the type bars pivot with something light like sewing machine or 3 in 1 0il. As far as the ribbon reverse goes it might be as simple as making sure that the ribbon is being fed through the ribbon reverse forks which are usually located left of each ribbon spool.
Good luck
Andrew
Jun 28, 2009 | Royal ET510 Typewriter
How to load ribbon and rewind ribbon.
The ribbon should reverse itself if it working properly. Just to the indide of each ribbon is a reversing that the ribbon should go thru, Move that arm away from the empty spool and type a few letters it should reverse. DickyO
May 31, 2009 | Royal Office Equipment & Supplies
Royal ribbon glitch
watch the ribbon spools as you type to see if they are turning.
May 21, 2008 | Royal Office Equipment & Supplies
Royal Portable typewriter ribbon
Hi, I have a Royal Companion Portable from 1940's. I bought new ribbons at mytypewriter.com (select the "Royal Portable" ribbon). It fits. Anyway if it doesn't it's not an expensive mistake, but I researched this and apparently all vintage Royal Portables have the same standard ribbon. Worked out in my case. Good luck!
Apr 09, 2008 | Office Equipment & Supplies
IBM Selectric used ribbon won't wind into spool
The ribbon sometime gets wrapped around the ribbon driver,One lever on the right side only releases the lift off tape for removal the other is for ribbon removal, also check that the ribbon is on the outside of the ribbon tensioner where the ribbon exits the cartridge on the left side ( a wire thing with a plastic tube on it.
Jan 29, 2008 | Lexmark Wheelwriter 15 Series II...
128 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
