Question about Ovens
No response from pushing pad buttons for oven
    Sergeant:
    Champion:
  • 269 Answers
Do you have power to the unit?
Posted on Oct 07, 2009
How do I start the self cleaning? I hit clean and it does not start
On most self-cleaning ovens after you push the clean cycle button you have to tell it how long you want it to clean. Try pushing clean then pushing 3:00 for 3 hrs. If you don't have a number pad try pushing the clean pad several times and see if it cycles through clean levels like low, med or high. Then after you tell it how long to clean hit start. If you don't have a start button the oven should start cleaning after around 5 seconds. It will lock the door and begin the clean cycle. Also remember it takes around an hour for the oven to cool and unlock after the cycle is finished. Hope that helps.
Aug 29, 2011 | GE JKP45 Electric Double Oven
After a power outage the oven does not work and F1 code appears.
the F1 code is a universal service code to ALL brand ovens and it means that one of the buttons on the touch pad has shorted out. You can clear the code by pushing clear/cancel button and if doesnt reappear it was fluke, if it reappears within 15 minutes and once again you push clear and that cycle repeats, the touch pad must be replaced
Good luck,
Gene
Jul 26, 2011 | Ovens
How do you change the key pad from celcius to ferenhite on my whirlpool acubake oven
Look for the button marked "Precise Clean" in the upper left corner of the control panel.
Press and hold this button for five seconds until the display reads "Temperature Unit Celsius.
Release the button and push it again for another five seconds until the display shows "Temperature Unit Fahrenheit."
Push the "Off/Cancel" button to lock in the Fahrenheit setting.
Jul 10, 2011 | Whirlpool SB160PEE Gas Single Oven
My Maytag oven was shut off when a breaker was tripped. We turned everything back on however the clock says " 5ab" and none of the buttons work to reset the clock. Without this function, we can't...
That is the sabbath feature, to get it or defeat it:
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Thanks for using Fixya, let me know.
Jan 06, 2011 | Maytag Ovens
The baking does not work
sounds like the touch pad or main control board could be bad...call for help on checking components....
May 12, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
When I push the on button after the oven is in "Snooze" mode, the oven starts cooling down instead of heating up . Then when I push the on button again, the screen comes up and says oven ready.
Pushing the Back touch pad will give Snooze option, push it again and the Oven Off comes up. From there you can leave it off to cool down and clean, or push the bottom right pad to turn on,
Jul 16, 2009 | TurboChef TORNADO Electric Oven
Help with dobble oven
clean the ribon conecto from the touch pad to the controller, use an pencil eracer to rub the ribon contacts
Dec 24, 2008 | Jenn-Air JJW8230D Electric Double Oven
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
