Question about LG RUMOR Cellular Phone
I have a Virgin Mobile Rumor 2. and i dont know my Bluetooth Passkey. i need it to pair with other mobile phones
    Problem Solver:
  • 10 Answers
If you are using your virgin mobile bluetooth first time always it will be the default with zero's.
Posted on Apr 29, 2010
How do i turn on bluetooth feature on my rumor 2
    • 1 Turn on the Bluetooth-enabled device and enable it to be in "Discovery" mode. Check the owner's manual of the device to learn how to put it in "Discovery" mode.
    • 2 Press "Menu/Ok" on the LG Rumor2, which is the middle button on the phone.
    • 3 Press " * " to access the settings menu.
    • 4 Press "1" for the Connections menu.
    • 5 Press "2" for the Bluetooth menu then press "1." Press "Yes" when prompted to turn on the Bluetooth feature. A list of available devices appears in the menu.
    • 6 Highlight the listed device, which should be showing.
    • 7 Click "Ok."
    • 8 Enter the passkey provided in the owner's manual of the Bluetooth device. The standard passkey is "0000." The Rumor2 is now paired with the Bluetooth device.
    • 9 Press the "Call" key on the phone or the "Call" button on the Bluetooth device to answer calls through a Bluetooth headset while paired.
Mar 01, 2012 | LG Rumor 2 Cell Phone
I dont know how to able the bluetooth of blackberry curve 8520??
Here are the pairing instructions for the Discovery 610 to your mobile device.
Bluetooth Pairing Instructions:
Look in your mobile phones manual for the section that describes how to set up a Bluetooth wireless connection.
1. Move through the menu selections on your phone until the phone display shows "Look for Devices," or equivalent, as a selection.
2. With your headset turned off, hold down the call control button until the headset status indicator briefly glows blue, then flashes red and blue. The headset is now in discovery mode and will stay that way for 30 seconds.
3. On your phone, highlight and select "Look for Devices", or equivalent, to activate the scan for the headset.
4. When the phone display shows the scan results, select "6xx Plantronics". The phone will continue to search for the headset.
5. When the phone display asks for a passkey, type "0000" and press Enter.
Your headset is now linked to your phone.
I hope this helps.
Good luck from Headsets Direct - 800-914-7996.
Aug 03, 2011 | Plantronics Bluetooth Headset 610 Wireless...
I need the passkey to install the bluetooth to my new phone, motorola H681
the default passkey for every bluetooth device is usually 1234. try it and let me know if it works. u have to pair it and enter the same passkey with your mobile/celfone.
Aug 07, 2010 | Motorola Mobility H550 - Bluetooth Headset...
Need code for g2 earpeice
Pairing the BLUETREK® G2
Before using the BLUETREK® G2 headset, you must pair it with your Bluetooth® mobile
phone. Pairing is the process of linking 2 Bluetooth® devices, so that they can
communicate.
To initiate pairing:
1. Place the BLUETREK® G2 and your mobile phone within 0.3 meter (1 foot) from
each other.
2. Switch on your phone and select its Bluetooth® discover mode (refer to the
Bluetooth® mobile phone user manual).
3. When the BLUETREK® G2 is switched off, press and hold the TALK button for
about 7 seconds until the indicator light flashes red and blue alternatively. And a
sound can be heard in the speaker.
4. Once the mobile phone detects the headset, a “BlueTrek G2” message will be
displayed. Follow the phone instructions to accept the pairing. The PIN code (or
passkey) is 0000, then press “yes” or “ok”.
If pairing success, the indicator light will switch to blue and flashes slowly.
If you haven’t started the discovery mode within 5 minutes, the headset
RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 19, 2009 | BlueTrek G2 Consumer Headset
I have a bluetooth from samnsung and tryin to pair it with my LG Rumor phone but i don't know the passkey
I took my bluetooth and phone to a Sprint store and the representative was able to pair it for me. Thank you and have a good day.
Apr 18, 2009 | Samsung Wireless Headset for...
How to get a bluetooth passkey
hi there,
if you are pairing the bluetooth headset device with your cell than the default passkey is 0000 (you can also check the user guide for bluetooth headset). and that will work with your phone.
if your pairing the phone with other phone then you need to create your own passkey to pair it with other device (try 1234) and the same key you have to write on other phone once you will do that your phone will be paired and you are able to use it.
i hope it will help you.
best of luck
Mar 23, 2009 | LG RUMOR Cellular Phone
Cant connect logitech bluetooth to phone,
the logitech head piece buttons must not be working, seems to charge ok but can't get to flash blue?
Aug 07, 2008 | Logitech Mobile Freedom Wireless Headset
Don't have bluetooth passkey
When you pair with someone you need a key(bluetooth passkey) for your mobile..for eg.
if A wants to pair with B.what he do is ,he go to the bluetooth menu .switch 'ON' to the bluetooth device and also selects 'shown to all' option so that other device can find that mobile .Now B also has to do same thing i.e switch 'ON' the mobile and 'Show to all'..Now Device A will search for other devices ,and when the search is complete you see the name of that mobile .now you click on that mobile and select to enter pass key..for eg 123 ..Now other mobile will get the message that Device A wants to connect to you i.e Device B.So same passkey 123 is to be typed in order to make pair............
Jun 01, 2008 | Cell Phones
Nokia 6680 wont connect to Bluetrek G2
Just had the same problem.
But I found some bluetrek instructions on the net & it works
communicate.
each other.
Jun 26, 2007 | BlueTrek G2 Consumer Headset
LG RUMOR Cellular Phone Logo
631 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
