Question about Refrigerators
Jenn-air refrigerator modedl ursd209. Has a really hot spot in front of the post between refrigerator and freezer. What is happening? Shall I call a repair man or looke for a new refrigerator?
    President:
  • 1,304 Answers
No its normal
this is the mullion heater or on some models the yoda loop
this gets hot to the touch
its stops humid air from harming the unit
pull the unit out and clean the coils
if its too hot that means your coils need cleaning
Posted on Oct 08, 2009
Jenn-air gasket is hot
The refrigerator portion is fed cold air from freezer section to cool it. Check for the freezer fan and/or the damper mechanism that directs air into fridge compartment for proper operation.
Sep 03, 2017 | Jenn-Air Refrigerators
JFC2087HRP Jenn-Air freezer creaking noise.
Most of the time this happen when the refrigerator has been hooked up to the water, and than you unhooked it!!, the water that is in the hose makes that sound when it's pushed by the air in the hose. that's a typical problem when you unhooked the water.
May 13, 2010 | Jenn-Air JFC2087HRP Side by Side...
Y jenn air side by side has water puddling out front left side, not under, I would also tie it ot the deforst cycle, maybe a clogged line, still cold, there is also some water underneath the lowest freezer...
There is a drain under the rear part of the freezer, see if you can see if it is blocked it may be fully of ice in the tube under it, if so turn off and pour hot water on it till the water drains out, put towels in the bottom of the freezer to collect this water, may take some time to get it cleared.
Apr 18, 2010 | Jenn-Air JCD2295HES Side by Side...
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Js42sefxda jenn air freezer dripping water from the top vent
Check that the drain tube for the defrosted water is not plugged. Someone on here just the other day had the same exact problem, and that was the problem they had.
Jan 28, 2009 | Jenn-Air JS42SEFXDA Stainless Steel Side...
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
