Question about ASUS M2N-MX Motherboard
Test points in motherboard
Dear Sandrew,
my motherboard is having nodisplay problem, please tell me which are signals and voltages i have to check
  • bhovi Dec 24, 2007
    dear Sandrew,
    Writing Tips:
    Please make sure that the 'Caps Lock' key isn't on, writing in all Caps is regarded as 'shouting' and is impolite.
    Please don't use shorthand writing, don't write '4 u' write 'for you'.
Feul injectors not pulsating
The voltage for fuel injectors go hot with the key on. The computer switches the ground on and off, check voltage and ground.
If the computer doesn't ground the fuel injectors, you'll have voltage on both legs.
If computer doesn't see rpm signal, it won't ground the fuel injectors. If no rpm signal check the crank sensor and ignition module, plus wiring circuits. Don't replace anything unless your testing points in that direction.
Jan 05, 2016 | 1994 Buick LeSabre
Frozen up with please wait read out on unit
Hello MrBrokeit, Shotgunning works sometimes, but the effort spent is often not worth the time spent. Let me explain if your power supply is defective then shotgunning will produce results, however if the problem is elsewhere you will never know it. I would suggest troubleshooting the unit, to determine where the problem really is. For this task I would suggest that you get a schematic diagram of the unit, a multimeter, and an oscilloscope. use the schematic to find the various test points, use the multimeter to measure the voltages at the test points, and then use the oscilloscope to measure the signals at the test points. Troubleshooting in this fashion will produce better results than as with the shotgun method. I would suggest checking for ripple voltage in the DC path. This voltage is due to AC bleed over from poor regulation by malfunctioning filter capacitors. you will not see physical signs of the problem but a quick check of the capacitors will let you know if the is the problem. Also check to see if the DC voltage across the positive terminal of the capacitor is held at the level it should be at. Then check all points on the power supply and compare them to the schmatic. Thank you, Shuttle83
Oct 09, 2007 | Panasonic DMR-E85H DVD Recorder
Comes on, nodisplay, resets after @30seconds
  • check CPU cooler
  • check video card
  • check memories
Apr 16, 2014 | Gigabyte GAH55MS2 Motherboard
Toshiba Satellite P205D-S7438 won't boot
You did everything that I would have done honestly, with the dvd drive not opening up and the fan not coming on, that would tell me the motherboard isn't regulating the voltage properly since neither is operating.
Either the CPU or the motherboard is bad at this point but I'm leaning toward the motherboard since a bad CPU would not cause a dvd drive not to open but a bad motherboard would especially if its not regulating the voltage properly cause of bad components on the motherboard. See if you can get the motherboard replaced if your machine is under warranty. If not then try to go thru Ebay since places there are less expensive.
Jun 02, 2009 | Toshiba Satellite A135-S4527 Notebook
26" flat screen akai tv
Hello RJ13,
This may be a problem in the HV section of your TV. My question is do you have raster, or is the screen totally black? If you have raster then this is a video problem, if the screen is totally black then it is a HV problem. In either case if you do not have a background in electronics I would suggest that you take your TV to a qualified TV technician. If you do have a background you will need the following items:
A schematic diagram of your TV set to know where the test points are and to see what voltages and or signals should be at what point in your TV set
A multimeter to measure AC voltages. DC voltages, and Resistance when needed.
An Oscilloscope to measure signals that should be present in various sections of the TV as shown by the schematic.
A signal generator to create the proper input signal for testing.
These are the major tools needed, not to mention a soldering iron, and a de-soldering tool
I hope this helps you,
Thank you,
Sep 20, 2008 | Akai CF2791 27" TV
Dear Flyman1957,
You can download the drivers from this URL :
Cheerup and enjoy
Mar 04, 2008 | Soltek SL-86SPE2 Motherboard
Tv Is not respondind
This denotes a problem with the power supply either the low voltage power supply of the high voltage power supply. You will need the following documents and equipment if you plan on doing this yourself: 1) a schematic diagram 2) a Multimeter 3) an oscilloscope 4) a signal generator (color bar, cross hatch, and purity) The schematic will let you know where the test points are and the level of voltage and signal are supposed o be at the test point. The multimeter will allow you to trace and measure DC and AC voltages throughout the set. The oscilloscope will allow you to view the waveforms generated by the signal generator, this is needed to tell if a component is not processing the signal in the proper fashion. The signal generator creates a standard reference to measure by. Since this prolem is in the power supply section you should determine if the problem is a blown fuse by visually inspecting the fuse. Than you will need to determine if the problem is in the high voltage power supply. You do this by checking the transistors in the horizontal section of the TV. you will find the problem either in the low or high voltage power supplies.
Oct 01, 2007 | Televison & Video
No verical
Hello gurdev, If all you have is a straight horizontal line across the middle of the screen, you have a vertical deflection problem. This may be caused by the opening of the vertical coupling capacitor, an open winding in the yoke transformer, the vertical drive transistor might be malfunctioning, or the vertical output IC chip might be defective. You will have to check all of these, make sure that you have a schematic, a multimeter, and an oscilloscope. Here is why: 1) schematic diagram to know where parts are and the voltages and signals present at test points. 2) multimeter to measure DC voltages on the pins of components 3) oscilloscope to measure signals at test points shown on the schematic. If you do not have a background in electronics please take your set to a repair shop, however if you have a background in electronics your troubleshooting will be around the vertical section if the tv. Thank you, Shuttle83
Sep 16, 2007 | JVC AV-27230 27" TV
ASUS M2N-MX Motherboard Logo
73 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
