Question about Kenmore Elite 45986 Front Load Washer
How to restart an interrupted front loading washer
I have a maytag neptune front loading washer. I lost electricity mid cycle - how do i get it to restart?? Just sittin there half full of water - wont drain or restart?
Thanks
    Problem Solver:
  • 5 Answers
Try unpugging for a minute and then plugging it back in to reset cpu board, if this doesnt work make sure power is getting to outlet, easiest way i know is with night light in same outlet, if u have a light trhen u have a cpu problem some of these units came with a five year warranty on the control board, u would have to read your warranty in your manual to find out.
Posted on Oct 08, 2009
Testimonial: "Thanks - somehow it started working again after many unplugs.... appreciate the feedback"
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Keep getting Lr halts with even the lightest loads. Takes hours to do one load restarting, adjusting, restarting.
This is a common issue with earlier Maytag Neptune Front Load Washers due to a momentary loss of motor control neutral feed from the power cord and result to the shutting down of the washer in the middle of the cycle. The neutral feed line needs to be checked for poor connection. Check the tip I posted regarding this problem and how to address it.
May 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune Washer has an error code "do" What does this mean?
The washer detects that the door is open when
starting a cycle or the door is not locking.
Close the door tightly and restart the cycle.
Nov 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Can't interrupt the washing cycle on coin operated Mah21pddww
Unplug the washer, wait three minutes for the door to unlock then do what you need and plug it back in. Should still have the time left on it that was there when you unplugged it.
Aug 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
170 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
