Question about Creative Labs Creative Technology Zen MP3 Player
Unit locks up. just reads
Unit locks up. just reads "creative" across the screen. how do I unlock it. it does it all the time and the battery has to die before it resets itself
  • 496 Answers
There should be a small pinhole in the back of the device put a paperclip or small pointy object in that hole and it will reset the device
Posted on Oct 07, 2009
I have a new galaxy S5 and i set it up with fingerprint to unlock but it keeps going reverting to password to unlock, how do i get it to stay on fingerprint?
Here is another way to unlock pattern lock for Samsung Galaxy phones, also works with password, fingerprint and PIN. Moreover, no data loss
http://www.youtube.com/watch?v=lw4ueft-t_I
Oct 06, 2014 | Cell Phones
I bought a used mp3 player put the battery died
There's a slide switch on the top of the unit, near the headphone jack. Slide it away from the jack to unlock the unit. Slide it toward the jack to lock the unit so that accidental bumping of the controls won't do anything.
Jul 07, 2010 | SanDisk Sansa e200 MP3 Player
Powered subwoofer doesnt work .stopped a couple of months ago.it reads SW on the amp display.sw is turned on -green light on-wiring is all healthy and snug.home theater hasn't suffered any abuse.always...
I sounds like you have blown the woofer. open the unit and check. first disconnect the leads on the woffer, then use an ohm meeter. If you don't have an ohm meeter use a 9v battery across the speaker terminals. If you hear a thunk when the battery touches the terminals the speaker is okay. If tyou don't it's gone. If the ohm meeter reads some number like 4 to 9 the speaker would be okay. If it reads nothing or 000 then it's gone. If you need a speaker you can order it from Pro Line Music 215-736-8055
Jan 15, 2010 | Audio Players & Recorders
Locked
Have you tried to remove the battery. If not, try this remove battery, see if that works. If removing battery doesn't work you may have to reset your player. First remove battery again, but before you put it back on, slide or hold your power on button, keep holding it down then insert battery. The load-up screen should come on asking to reboot, cleanup , or reload firmware. Just reboot and see what haps
Feb 01, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
CPU is locked!
remove the battery from the unit and allow it sit for a couple of minutes then plug in the unit to power and see if it somes up. Removing battery and power often unlocks a unit. make sure hibernation is not causing problem. Once it comes up successfully, power off and reinstall the battery, try again. Some times a failed/failing battery can lock things
Jan 06, 2009 | HP Vectra VL400 PC Desktop
"PLAYER LOCKED"
Allow unit to run dead.recharge battery.turn on and push reset(small paper clip in reset hole).turn off and back on .should now work.if not format and download new soft ware at http://support.creative.com/kb/ShowArticle.aspx?sid=8451.RICHARDM69
Nov 09, 2008 | Creative Labs Zen Neeon MP3 Player
How do i unlock a jvc home stereo
On the unit, press the stop button and the cd eject button at the same time. The screen will say locked still. Release them and press them together again at the same time. The screen will now read unlocked. You can then eject the cd.
Oct 15, 2008 | JVC TH-C60 System
Will not turn on.
I read of the following fix for the nomad II, you could try and see if it works for you: 1. Turn unit to "locked" position. 2. Hold down the "stop" button. 3. Continue to hold the "stop" button, take the battery out of the unit. 4. Still holding down the "stop" button, put the battery back in. 5. Continue holding down the "stop" button until a screen comes up with "backup code", wait a few minutes and then switch unit to unlock and take out a battery. 6. Put the battery back in and you should have a working unit. There have also been reports of loose terminals within the unit causing the batteries to not make good contact. Be sure the batteries are in tight. Does it turn on when connected to PC? if so you could try updating the firmware. Good luck
May 14, 2006 | Creative Labs Nomad MuVo TX MP3 Player
Creative Labs Creative Technology Zen MP3 Player Logo
112 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
