Question about OKI MICROLINE 320 Turbo Matrix Printer
I am trying to print a label that prints correctly on a ML420, but does not print on the ML320. I am getting line feeds and is printing on 3 of the 3x5 labels instead of 1. On the 420 the labels print correct - it is set with 3x5 in the paper option. I can't seem to do that on the 320
  • mprodor Oct 07, 2009
    Thanks - we have set this printer up as a network printer where labels are generated out of an Oracle Application. I set the print quality and the pitch on both printers to be the same, but I will have to check the other options. AS soon as I find them , I will let you know.
    Sergeant:
    Champion:
  • 208 Answers
It would help if you can illustrate how it is printing. What OS and driver are you using anyway? Is it connected to a parallel printer port? Are you printing directly to lpt1? Or are you printing through a printer driver?
Did you verify the settings of both printers? The print the settings, hold shift and press select, then press print/park button. Check the following settings, page length, line spacing, skip over perforation, auto CR, auto LF, ESC SI pitch, and auto feed XT.
I will be able to help you isolate the problem when you post the information I need.
Posted on Oct 07, 2009
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
When I print a label I have to press the feed button to get the label out. How do I get it to push out the entire label without me having to feed and reset the whole time?
Most people I know print addresses from a sheet of labels, which ejects at the end. It sounds like you are printing one address from a continuous roll of labels, and they are so close together that the printer cannot push it out for you without misaligning the next one. I think both systems are designed mainly to print a batch of labels at one time.
If you are printing a batch, it is best to prepare the whole set first and save it as 'data' for printing addresses. For a one off or just a few I would use a sheet of 24 labels (say) with 3 to a row, and 8 rows.
Does this help?
Jan 06, 2014 | Argox OS-214 Label Printer
The printer will print one label correctly, then feed out a blank one. when the next label is printed, the printer reverse feeds the blank label into the printer to print the next one, but not far enough...
This sounds like a size issue, meaning that your label has too many lines and that kicks to the "next page".
Look for too many line items on first label.
Oct 06, 2010 | Zebra Z4M Printer
Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
Nov 04, 2009 | Zebra TLP 2844 Label Printer
Why is my Zebra printer printing every other label?
The labels you are printing have an extra line feed (a blank line) after the last printed line. Remove them.
Remove any "FormFeed" from the label run, if you are doing a "merge".
Line 1 Name
Line 2 Address
Line 3 Address2
Line 4 City St Zip
Line 5 <Blank>
Line 6 <Blank>
Sep 21, 2009 | Zebra LP 2844 Thermal Printer
Tlp 2844 printing first page ok then prints another blank
First thing to try is a reset of the printer.
1) Turn printer off.
2) Hold down feed button whilst turning printer on.
3) Let go of the feed button as soon as it starts to flash and then wait.
4) Printer will measure out 4 labels then print out a Hex dump ending with a not to "Push Feed to Exit"
5) Push feed
Follow the above instructions, if you mess around tapping the feed button (not following the above) you can change the printer between line mode and page mode. To swap that back is another storey.
David
Jan 03, 2009 | Zebra LP 2844 Thermal Printer
Not printing the correct text / picture
your in line mode instead of page mode.
  1. Turn printer power off.
  2. Press and hold the feed key, then turn power back on.
  3. When light starts to flash, release finger from feed key.
  4. When light starts to flash again, press and hold the feed key until the light turns red (or amber), then release finger from feed key.
  5. Wait for light to turn solid and press feed key once.
  6. Check to make sure you are in the correct printer mode by printing a configuration label (Click here for configuration label example - Note item C).
Jun 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Printer won't print labels
What driver are you using ? the default driver should be IBM Proprinter.
Hope this helps
Dezzi
Jan 24, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata ml390/391 Turbo
you have to set this on your computer. when the print box comes up you need to choose the label catagory to make your printer print labels just right
Aug 06, 2007 | OKI MICROLINE® ML390 Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
52 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
