Question about Ruud UBHC Air Conditioner
My heatpump has quit working I have checked voltage to out door unit it is fine. I have checked low voltage to make sure it is calling it is showing 24 volts from blue to yellow. I have check the uf on the capacitor it is good. I am getting correct voltage into contactor. please help
  • 89 Answers
If all the voltages are correct you might have a bad contactor. Check the low vltage wires that controle the contactor and see if you have >24 volts. There also might be a low pressure not letting it come on.
Posted on Oct 08, 2009
My Heatpump keeps running and won't shut off
If just your outdoor unit runs all time your contactor my be stuck closed.if this is caseturn off high volts to both in snd out door units.look inside out door unit control panel if contactor is pulled in it that is your problem some times taping cantact gently will unfreeze it .if this is not problem and both in and out are RUNNING all time you have low voltage problem s I would start at airhandler
Feb 27, 2015 | Heating & Cooling
We replaced fan motor on heil heat pump , now the defrost isn't kicking in, is this a wiring problem or unrelated to us replacing the fan motor?
Check low voltage at heatpump need 24voltsat R and C tterminal s if you have 24 volts on defrost board change board .if you dont have 24volts from r and c you have to go to indoor unit and look at low voltage wireing . Check wire nuts or when replace ing motor might have knock some loose check all low voltage. Hope this helps
WIREIN HEAT PUMP FOR COOLING ONLY
You must wire Orange from heatpump low voltage wire to gether with your yellow s and you must have a common wire usealy common comeing out of heatpump should be black color than what ever color wire you have connected to common at t-stat and airhandler connect that to black wire at heatpump. To make sure blablack I s common follow wire up to board and it will be connected to C terminal now you will have ac all time. If you want heat remve Orange wire from reds at heatpump and you will get heat only.note when doing your wireing make sure high voltage is off to heatpump and airhandler hope this helps
Feb 27, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
My unit is not putting out power to the thermostat. It's a heat pump with aux heater. Voltage tested between R and AUX/W2 posts show no Amps. What could cause this?
You have to go to your indoor unit its called a airhandler check high voltage going to unit should be 240volts .if you have 240volts look to see if there is a fuse either on the board or in line it will look like a car fuse 3amp or 5 amp check if fuse is blown but before checking make sure you pull disconnect so you dont have any high voltage going to unit. If fuse is blown get same exact fuse auto parts store will have them replsce put stab back in diconnect unit should run .if there is no fuse in airhandler keep high voltage on go to transformer and check for low voltage comeing out of transformer .NO 24 volts comeing out .replace transformer.if you have 24 volts comeing out of transformer check low voltage wireing thermostat wireing one goes to thermostat and other goes to out door heatpump usealy Brown in color and will have 8 small different colors wires inside brown jacket. Check for 24volts between red wire and common should be blue color if it is color coded. If no voltage there is a break in red or common wire.or sometimes just wirenuts need to be retightin.also when checking for low voltage one leed must be on common and other lead goes to red.also with high voltage off take face off thermostat carefully make sure all connections are TIGHTEN. This will also so you witchcolor wire is common it will be connected to C terminal hope this helps.note must have 24volts red and common or t-stat will not light up.hope this helps
Feb 26, 2015 | Heating & Cooling
Where is the low voltage 24 vac transformer located?
The transformer is located in the furnace. You might want to check to make sure the furnace door is on correctly brcause theres a swich that will open for safety . Also some have a fuse on the solid state board.
May 26, 2014 | Rheem RASL024JEC-RHPNHM2421JC 2 Ton 18.50...
2005 s type jag a/c quit blowing cold air suddenly .just blows hot at any setting or on auto
hi,is this a heatpump or a ac unit only...if a heatpump ,there is a valve that switchs from heat tocool mode...go outside with unit running..put hand on big copper line,if it is hot your in heat mode..if cold your in cool mode....possible stuck change over valve if a heatpump...hope this helps...good luck...michael doctor airr appl.repair..843-384-8474...if need more assitance..call..its free...good luck
Mar 26, 2010 | Heating & Cooling
Heatpump A/C not working
First,Turn on the heat cycle (Not Emergency)and see if the outside unit come on,If not,and you don't have low voltage outside,Go to the inside unit and test the transformer,If you have low voltage from the transformer but not outside,It is the low voltage wires,If you don't have low voltage from the transformer,It's the transformer.If you have low voltage outside when in heat mode,but the unit won't come on,It's the contactor.Let me know if you need more help.
Please take time to rate this fixya
May 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Two lennox heatpump 71/2 tons
check the true psi with the line psi to see if same if psi is good in cooling 225 hi and 70 low on 80'day then compressor is fine and i would start checking for temp difference on the reversing valve sometimes this will cause high suction or high discharge psi shift it manually with by energising it be cooling or heating then pull wire and see how it shifts if shifts good then txv on out door unit could be bad what is the psi in heating on the discharge line going to the indoor unit? most prv's are set at about 350 psi r22 as for suction line size its only hot gas in hp mode os no problem their shows in cooling mode as low suction psi ..hope this helps some also make sure indoor coil is clean!....thanks & rate me
Apr 19, 2009 | Ruud UBHC Air Conditioner
Intertherm ac/heater in a mobile home shuts off and won't come back on for quite a while. Then it runs fine for days, weeks, sometimes months. HELP
I am assuming it's an electric unit (most are). Sounds like there is a low voltage short somewhere. This could also be a thermostat problem as well. If it were a relay switch, it would not work at all because when they go bad, thats it they dont work anymore. There isn't an inbetween. I'm leaning more towards a low voltage short. Make sure that your low voltage wiring is tight and not loose. Be careful not to work on the unit with power to it.
Mar 14, 2009 | Heating & Cooling
My 2 T. coleman heatpump stopped working, it makes a feint buz but does not start.
If you are not comfortable working around High Voltage, do not attempt to fix anything. At your own risk, there will be two small wires going to your outside unit and one set of larger wires. The larger set powers the unit with High Voltage. Leave them alone. The smaller wires carry Low Voltage and energize the control on the condenser. If your thermostat is not sending a signal, these two small wires will not have any voltage running thru them. Check for 24 volts when the thermostat is calling for Cool. For a quick test, jump out the terminals where the two wires connect and see if the outside unit starts. If not, you have issues that will require a technician. If it does start, check the wires for any breaks or bare spots and replace if you can. Check the thermostat and make sure it is in fact calling for Cool. Replace any batteries in it or jump out the same two wires at the thermostat and see if it starts. You may need to replace the thermostat if it does start.
Jul 30, 2008 | Heating & Cooling
Ruud UBHC Air Conditioner Logo
60 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
