Question about Motorola Mobility MOTORAZR2 V9 Cellular Phone
It is jammed and does not want to turn on - Motorola Mobility MOTORAZR2 V9 Cellular Phone
  • 32 Answers
I think you have broken it.
1.Dont drop it in water
2.Dont drop it on hardware
3.Dont drop it anywhere
4.Dont do to much at the same time to make it freeze
If you did any of these things you have broken it
Dont panic
Posted on Oct 07, 2009
Tip
Error Code & in washing machines..
Error 7 means - “Motor jammed / Drum shaft jammed / Tacho generator fault”
Motor jammed
The first possible fault could be if the motor is trying to turn but the motor is physically jammed. This is likely to be rare. It’s easily tested by opening the door on the washing machine and spinning the drum by hand. If it moves normally and freely it’s clearly not jammed and this is not the fault.
If it is jammed or very stiff then making sure the machine is disconnected from the mains supply you can just take off the drive belt. You can then see if the motor is jammed or not because the shaft where the belt fits wouldn’t be able to be turned by hand.
Drum shaft jammed
This would cause the exact same problem in that the motor is trying to turn but because the drum was jammed it couldn’t. Again, easily tested by turning the drum by hand – if it’s free then it isn’t the fault. If it’s jammed or very stiff, removing the belt will let you determine whether it’s the motor or the drum that’s jammed.
The way a washing machine detects the speed of the motor is via the tacho coil which is the last potential fault listed.
The tacho coil is on the outside of the motor attached to the end opposite the drive belt with 2 thin wires running from it. It’s a small coil that surrounds the shaft of the main armature where a small round magnet is attached. As the armature turns the magnet on the end of the shaft turns inside the coil. It’s then easy for the pcb to count each revolution of the small magnet and work out how many revolutions per minute it is turning.
on Mar 17, 2010 | Washing Machines
CHECK 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
shown, then press [Stop].
Pull it gently in either direction.
If you cannot pull the paper out, continue with the steps below.
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
The fax returns to standby mode.
Feb 20, 2012 | Office Equipment & Supplies
A piece of paper jammed up. I took the paper out but the alarm keeps on saying "Carriage jammed"
Hi there !
Check again your printer and maybe there is still paper jammed inside. Turn off your printer. Open the door cartridge and remove the cartridge. Check for paper jammed. After that return the cartridge and turn on your printer. Sometimes there is paper jammed inside that printer. Just press the power off and turn it on to roll over any paper jammed inside. Turning off on your printer also make your computer refresh the memory of your printer paper jammed.
To make hard reset of your printer. Turn off your printer and remove the power cable to your printer, leave it for five minutes and connect the plug and turn it on again. That will refresh the memory of your printer.
I hope it helps you.
Jan 25, 2011 | HP Officejet 7310 All-In-One Printer
Our printer is not picking up the paper from the tray and is saying it is jammed. There is not jam.
Hi there !
Is your printer had jammed before and it stop printing in the middle of printing? For some reasons, paper can jammed due to printing interruptions, printer turn off, improper loading or feeding of paper, roller feeder had problem and others.
If jams before and paper have let inside the printer, please do the following first:
1. Check th paper tray, see inside if the paper is jammed inside that compartment. If there is paper jammed, remove, turn off your printer and turn on. This will solve your problem.
2. If not, open the printer cartridge door, remove the toner cartridge and look for paper jammed inside. If these is paper inside, remove it, turn off the printer and turn it on.
3. If you cannot see the paper jammed inside, the paper maybe inside the heating area. To remove paper, just turn off your printer and turn it on to roll over the paper jammed inside of it.
4. If the printer is blinking and saying there is paper jammed. You have to check the cartridge toner by opening the cartridge door, remove the cartridge and return it back but be sure it is well firmly fitted.
If following the 4 diagnostic procedure and you cannot locate the jammed paper, the problem lies on the toner cartridge itself. When toner cartridge is not rolling over, it will stop feeding the paper and it will cause printer to jammed.
To diagnose the problem, put old printer cartridge and if no toner power, just shake it well and I am sure there is still small amount of powder inside it and if it prints, the toner cartridge you purchase is defective. Reason, factory defect or improper refilling and part is not working well.
I hope it is helpful and thank you for using FixYa !
Jan 06, 2011 | HP LaserJet P3005n Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
MY K-JAM
i suggest format your phone and download rom a gain to your phone
Mar 19, 2008 | i-mate K-jam Smartphone
Clear paper jam
does the printer have a cancel botton if it does push it
Feb 14, 2008 | Lexmark X5150 All-In-One InkJet Printer
Motorola Mobility MOTORAZR2 V9 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
