Question about Microsoft Xbox 360 Console
How do u setup the Xbox live gateway,we can find everythhing except that.Can you help me?
    President:
  • 2,777 Answers
The gateway is the router you are connecting the xbox 360 to... you may need to configure the router... If it says you have a restricted connection on xbox live you will need to. Otherwise everything should be working fine. Here are the settings you will need for the router if applicable:
http://support.microsoft.com/kb/908874
Posted on Oct 13, 2009
XBOX Live Problems
Did you buy this console second hand?
It looks like it was banned from the Xbox Live service due to having modified the console.
If this is the case you will have to get in touch with the person who sold it to you.
If this is an unmodified console and you are having problems connecting please go to following page where you have Microsoft's original documentation:
Check it out here: http://support.xbox.com/support/en/us/nxe/xboxlive/default.aspx?WT.svl=nav
Hope it helped.
Nov 18, 2009 | Microsoft Xbox 360 Console
Tip
Xbox Live - MTU Error
Xbox 360 MTU errors
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
on Sep 30, 2008 | Microsoft Xbox 360 Console
Xbox live is not working it keeps coming up with 'you need an active connection to play online or system link matches' but my connection is fi and none of my friends can play as well?
Suggestion: <b>MTU Error</b>
Things to try:
Sep 30, 2008 | Video Game Consoles & Games
Mtu failure
Things to try:
Xbox live cant connect mtu failed
This appears to be a common problem, most likely due to the recent Xbox Live server maintenance. Nothing we can do except for wait until Microsoft fixes things on their end.
MTU setting
Browse to the router's setup page, should be 192.168.1.1 or 192.168.1.0 and log into it. You just have to change the MTU. Put it to 1500.
Once logged in to the router, go to :
Setup
Basic Setup
Wireless Setup
Internet Connection Type
Connection Type = Static IP
Internet IP Address = 192.168.0.1
Subnet Mask = 255.255.255.0
Gateway = 192.168.0.1
Static DNS 1 = 192.168.0.1
Static DNS 2 = 192.168.0.1
Static DNS 3 = 192.168.0.1
STP = Enable
Optional Settings (required by some ISPs)
Router Name = client-mode
Host Name = 2WIRE383
Domain Name = [empty]
MTU = Auto
Please remember to rate all users who assist you for free :)
Sep 29, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Computer, xbox live setup
the easiest way is to use another computer connected to router in any way.
windows xp os.
click start/run type in : cmd
then type in : ipconfig
there is the default gateway number.
Jan 26, 2008 | NetGear WGR614 Wireless Router
Play on xbox live via wireless
First your setup should be, wall (isp) > Actiontec DSL Gateway > Zyxel router > your computer
If that is already setup right, try the ip address of 192.168.1.1, some routers use this ip rather that 192.168.0.1
Hope that helps.
Jan 13, 2008 | Zyxel Prestige P-330W Wireless Router...
Xbox 360 live
- double check that your network cable is plugged in correctly on both ends
- verify the cable works by using it to connect a computer or other console to your network
- if using wireless adapter double check that it's plugged in to the rear USB port securely
- consider using the setup blade to reset your console and re-do the setup wizard again
Oct 30, 2007 | Microsoft Xbox 360 Console
MTU con connecting. How to fix ?
What does MTU do on Xbox Live?
The MTU of your router or gateway must be greater than or equal to 1365. If it is less than 1365, you won’t be able to connect to Xbox Live.
To change the MTu login to your admin router panel:
  1. Go to start>Run>cmd>type ipconfig
  2. look for "default gateway" then type that address into your router login, usally the login is admin/admin if not look in your manual or call your router maker.
  3. Now login locate the area to adjust the MTU if you cant find it, contact the router maker, or look in your manual.
More info:
http://www.xbox.com/en-US/support/connecttolive/xbox/connectionmethods/diagnosingconnections.htm
Cam
Oct 21, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
