Dear..... to do it set.... you have to open the box with due care as the electricity of the equipment should be turned OFF.... There is a main cable connected with the center of CRT and going onto a section of board called flyback.... is picture can easily been seen on net..... the rotate is anticlock slowly and you will find that brightness of you CRT is getting dimmer.... set is where you want.... actually its screen voltage regulation
SOURCE: my sony has an issue
if there no menu button means just after loading os go to properties by right clicking in desktop there u go to settings tab go to advanced option.. there u will be having the tab some thing like intel extreme graphics go to that go to display properties there u will having the option to adjust ur height and width of the screen area... check this out...
SOURCE: Menu pop ups
It will only be one of 2 things, neither easy to correct I am affraid.
SOURCE: sony projection tv convergence issue
You will need two STK392-560 Convergence ICs and you will also need two of the 3.5 amp pico fuses as Sonys will always blow at least two of the Pico fuses. You can get replacement ICs and Pico fuses at the fiollowing link and they provide free instalation instructions. Heres the link.
http://servicemanuals.vstore.ca/
SOURCE: Can not upgrade firmware v1 tov4 in a Sony a200.
there is know update in firmware for a 200 the v4 update is for the a700
SOURCE: Front panel buttons and remote have stopped working.
Is the favorite channel menu a function that is normally accessed by a button on the remote?
If so, that button on the remote might be stuck.
If this is the case, the menu may at times pop up all by itself and other buttons on the remote and on the TV's front panel may not respond at all (it had happened on my remotes more than once).
Try to clean the remote control (the housing, rubber pad with knobs, circuit board) with ethyl alcohol, when you clean the housing, you should also clean the holes through which the buttons protrude, there might be some dirt that keeps the button stuck.
It may also be a stuck button on the TV front panel, so check these too.
Also, it could be something else, i just wrote the description of a problem and the solution which to me seemed most likely.
Hope you get it fixed.
regards
3rq8 (Triarcuate)
