Question about Check Point Network Adapter
I have an electric safe with no keys, when I put in my code, the light flashes and beeps at the proceed light what do i need to do to get this safe open.thanks Nick
    Problem Solver:
  • 6 Answers
I have just change the batterys on my sandleford electronic safe ES23. now I can not put my same code back in. can u help me please. it has a key n a key pad as well.
Open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code, then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Jun 27, 2016 | Locks & Locksmithing
How to change code N15115
Input the new code (1-8 digits then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again Emergency Key - store in secure place NOT inside the safe. To ensure the batteries have been installed correctly test before closing the door. 2 bolt locking mechanism, opens with a digital code or emergency key. Floor or wall mountable, immediately locks out after 3 invalid code attempts. Durable steel construction, model Name 24/7 Digital Safe, material, galvanised steel. Opening the safe a. Pre-set factory code 159 b. Input 159 (the yellow light will flash and the buzzer will beep then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened Closing the safe: close the door, input the code (the green light.
Feb 01, 2015 | Home Security
I bought a house and have a hardline safe is there a way to reset the safe password. .
User override key to open safe.
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
May 03, 2011 | Locks & Locksmithing
We have a Sentry safe model number SC 3877. We just changed the batteries. We are imutting the correct code, the light turns green but does not give the 1 beep and we cannot open the safe. If we put in...
http://callitout.com/quotes/index.php/kick-it-to-the-curb/55/sentry-fire-safe-wont-open-its-broken/
Its the most reazonable answer and it worked!!!!!!! dial the code and tap on the handle so it would get lose
Jan 16, 2011 | Sentry Fireproof Safe
I forgot the code to open my Hardline Digital Electronic Security Safe S2120. I need help on how to open it
Comment by jwlevan September 17, 2009 5:59 pm
does she have the user override key? I found this...
Then:
..might help ya out..but i'm no guru w/ safes by any means!
Sep 16, 2009 | Office Equipment & Supplies
My safe is open i have key but need to change combination forgot original numbers and how many numbers i need and how to do it i have lost paperwork could you please help me i am not to clever at this i am...
You need to open the door and press the red button inside the safe, on the door, near the hinge. Yellow LED will go on. Enter your new code (3-8 digits) followed by the hash key '#'. Yellow LED will go off to indicate the new code has been accepted and stored.
If the new programming attempt fails, the Yellow LED will flash with 5 beeps. You must attempt you new code again.
Aug 24, 2009 | Kitchen Appliances - Others
Can't get it open after keying in code. error
http://www.sentrysafe.com
the instructions are located link above.
mj
Jul 08, 2009 | Sentry Fireproof Safe
I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
Then:
Apr 27, 2009 | Safe International Digital Electronic Safe...
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Forgot pin code to unlock my hardline digital safe
I have pin code but batteries went flat while I was on holiday, how do I unlock my Hardline digital safe? I do not have override key
Dec 09, 2008 | Safe International Digital Electronic Safe...
Check Point Network Adapter Logo
385 people viewed this question
Top Check Point Computers & Internet Experts
steve morris
steve morris
ray gallant
Are you a Check Point Computer and Internet Expert? Answer questions, earn points and help others
