Question about Apex Digital Televison & Video
Need remote codes for apex rm 1200 - Apex Digital Televison & Video
  • 2318 Answers
SOURCE: Codes for a Sony remote RM-Y137.
Try these ones:
RCA / Proscan - 304,305,308,309,311,312,313,310,329
Posted on Apr 11, 2008
SOURCE: NEED CODE FOR APEX TV
try buying an apex remote control
Posted on Aug 31, 2008
  • 155 Answers
SOURCE: philips universal remote codes
Hi Troysingleto. The code can depend on what model of URC you have. According to a site I found by Googling, the code for Apex TVs on one common URC from Philips is 044. Here are the steps to input it directly:
1. Press and hold the Code Search button until the red indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV, DVD, etc). The red indicator blinks, then stays lit.
3. Enter the 3 digit code (044) . Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the device responds, no further programming is required. Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
If that code does not work, you can still find the code using this manual procedure first posted on FixYa by cptnkirk4064:
1. Manually turn on device to be controlled.
2. Press and hold the "Code Search" button until the red indicator light stays on, then release it.
3. Press and quickly release the desired code button (TV, VCR, etc). The red indicator light should blink once.
4.Press the "Channel Up" button repeatedly (up to 300 times) until thedevice to be controlled changes channel. The red indicator light shouldblink off with each button press. If you accidentally overshoot therequired code, press the "Channel Down" button to backtrack through thelibrary until the device changes channel. Pressing "Channel Up" changesdirection again.
5. Press and release "Mute" button to install the code.
If you wish to actually identify the code once this has been done, this is the procedure:
1. Press and hold the "Code Search" button until the red indicator stays on. Release the "Code Search" button.
2. Press and release the desired mode button (TV, VCR, etc.). The red indicator light blinks and then stays on.
3. Press and release the "Code Search" button. The red indicator light goes off.
4.To find the first digit for the code stored under the mode key pressedin "Step 2" press each numeric key from 1-9 in turn. When the redindicator light blinks off, the number you pressed is the first digitfor the code you are searching for.
5. To find the second digit,repeat "Step 4," this time when the red indicator light blinks off,this is the second digit in your number.
6. Repeat again for the third digit in your code number.
Once I find out the code for my TV or DVD player, I write it on a small piece of paper (make sure to note which unit code is for!) and tape it to the inside of the lid to the battery compartment for future reference.
Best of luck!
Posted on Feb 14, 2009
SOURCE: code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Posted on Dec 06, 2009
tthekraut
  • 374 Answers
SOURCE: need apex tv code
the standard codes for apex are: 0023, 0223, 0123, 1814, 0741 .try each one of these until you find what works with your tv.
comment if you need any further help or if these do not work.
Posted on Mar 17, 2010
Does an Apex RM-3800 remote control work for an Apex AT1314DV television.
Should work. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 24, 2014 | Televison & Video
WHAT IS THE CODE FOR PHILLIPS TV THROUGH APEX REMOTE
With most model apex remote controls won't have a set-up code to Philips TV.
Jul 30, 2014 | Apex Digital Apex RM-1300 DVD Remote...
Need TV and DVD codes
0408 0421 0469 0654 0767. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Mar 21, 2014 | Apex Digital APEX RM-1010W Remote Control
I need the JVC TV Remote code for the Apex RM-1010w remote
Codes to check with JVC TVs are: 0060 0026 0197 0069 0247 0923 0012 0065 0067 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you wish to get more details, check this.
Dec 28, 2012 | Apex Digital APEX RM-1010W Remtoe Control
How do I program my Direct TV remote so my Apex ad-1200 dvd player works
How do I connect JVC DVD Video recorder RM-SDR107U remote to Sony TV?
Sep 11, 2011 | Apex Digital AD-1200 DVD Player
Whats the code for an Apex DT 504 converter box, I have a Sony RM-vz220 universal remote
try the Samsung codes. Apex used their chassis for a while.
Please let me know if this works
Good luck and rate FIXYA when its done :)
Mar 28, 2011 | Sony RM-Y168 Remote Control
The remoate that came with tv is not turning the unit off or on . we have tried to program a universal remote it the tv will not takr the codes. what are we doing wrong?
You may have the problem in the IR receiver in the TV itself.
Is the remote code for APEX listed in the remote user manual? Brand of this remote?
Not too may universal remote will support APEX DIGITAL TV, you can try SONY universal remote RM-V210 which has APEX TV in the listing
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMV210#
Mar 25, 2011 | Apex Digital LD4088 LCD TV
Trying to program Sony RM-V202 universal remote for an APEX tv
Press SET and POWER button at the same time, press TV,press and release the CH+ button,then press and release the POWER button, each time you press CH+ and POWER button a code is entered. Keep trying until the TV goes Off. It may take 70 trys, when it does turn off press ENT.button to save code. hope this helps..
Apr 01, 2010 | Sony RM-V202 Remote Control
Televison & Video Logo
467 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
