Question about Sony KP-53S35 53" Rear Projection Television
Convergence or D board problem?
I have an issue with the upper right corner of the picture bending the RGB so I see all three individually, but just in that corner of the screen. A tap to one of the connectors on the board will snap it out of it for about 20 seconds, only to return. I have resoldered all connections on the bottom of the board with no fix. Could it be a cap?
    Genius:
  • 1,694 Answers
You missed ! Be more on target and you will get it done....
Solder all convergence IC pins and any suspicious connects
in area of convergence circuitry AND solder all board edge connectors, both boards...........Next, try to isolate with tapping
technique................Last,no it cannot be a cap, but it could be
internal in one of the STK amp IC's......................T.
Posted on Dec 24, 2007
Picture bends at top and bottom, colors distorted-rgb out of alignment tried realigning with menu-no sucess replaced convergence board-no sucess does it need some fuse replaced or could it be the high...
Go to menu then setup if you do not see convergence in menu then you have blowed fuse FL231 on the Deflection Board.
If you have convergence then with OFF Press and hold VOL- CH-
at same time wait till TV comes on release Now you should be in Factory Settings.
Oct 01, 2010 | RCA R56WH76 Projection Television
Convergence is off in the lower right and upper left corner
The repair isn't too complicated if you're comfortable working with a soldering iron. Sounds like one of the "guns" is shot. The chips that need replacing are attached to the heatsink on the convergence board. The reason for replacing both chips is if you're going to bother to take the board out and replace one bad chip, that is the best time to replace the other older chip. The link below is to step by step instructions including pictures of the repair. You can check it out to see if you want to try it. If not, the repair is expensive (between 250-400) depending on the repairman. Best of luck with your convergence problem.
Greg
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
May 23, 2009 | Toshiba 50A61 50" Rear Projection...
Picture is all distorted ,colors dont match up need 3d glasses to watch
HI, this is basic convergence failure. the convergence board controls the RGB stream and , if its malfunctioning or, the convergence chip set is damaged, it will distort the entire display and the colors will not be regulated correctly as you are experiencing at this time.
simply replacing the convergence board in this unit will fix your issue.
May 18, 2009 | RCA Televison & Video
Blue spot on screen
Hi. this is called convergence failure. the convergence board is a circuit board that regulates the RGB(RED BLUE GREEN) streams that make up the color picture. If the convergence board chips are malfunctioning, you will see a distorted view of these RGB streams. This is what you are experiencing at this time.
Simply replacing the convergence board or chips will fix this issue.
Please rate and have a great day:)
May 17, 2009 | Televison & Video
Bent Picture at top and bottom
You have bad convergence amps.The fluid may need to be changed if the picture had a hazey look to it before the convergence went bad.
Dec 13, 2008 | Philips 60PP9202 60" Rear Projection...
Philips Blue Shadowing
If you have not already done so go into the picture menu and set the convergence. The convergence is the angle at which the three picture tubes meat at a given distance. The tv will have at least 3 and up to 64 convergence points, and those 64 can be set for all three colors. This can be tiresome but I'll be it will solve your problem. What your trying to do is get the color in the cross-hair so you cannot see the color behind the target. On top of the fine setting for each point and color you will probably have 3 gross adujustments for blue and green and maybe red. These adjustments will affect positioning, like what you are discribing. You should do this at least every month, the thermal cycleing of the lamps is what will cause this to creep out of adjustment.
Sep 25, 2008 | Philips Magnavox 9P6034C 60" Rear...
Convergence issue
You need to replace both STK392-560 convergence ICs and some of the 4.7 ohm 1/2watt resistors. You can get replacement ICs and resistors at the following link with free instalation instructions.
http://servicemanuals.vstore.ca/
Jul 23, 2008 | Sony KP-46WT500 46" Rear Projection...
Convergence problem?
The convergence anp ICs are usually what go bad in that unit. They are two ICs both are STK392-040 and they are at board location ICZ103 and IZC103 on the Sub Board attached to large heat sinks. You can get replacements with free installation instructions and free on line tech support at the following link.
let me know if you need further assistance.
Apr 10, 2008 | Samsung HCL4715W 47" Rear Projection...
Selective "non-convergence" issues
Sounds like to may have a yoke loose on a tube. If it's not that, you may have somehow damaged the convergence board. Look for any cracks in the board. If you find any, solder across the beaks and it should be fine. Good luck and I hope this has helped in some way
Ed
NC Electronics
Mills, Wyoming
Feb 18, 2008 | Sony KP-53V80 53" Rear Projection...
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
