Replace bearing model MAH4000AWW
    President:
  • 1,304 Answers
For this repair you will need two parts,
1 the oter tub
2 the spinner assembly
the bearing is pressed in to the back of ther outrr tub
and the spinner assembly is the shaft that goes through the bearing
personallyy i would buy a new machine
this reapiar is a complete rip down and reassembly
Posted on Oct 07, 2009
Loud Bearing Noise During Spin Cycle- MAH4000AWW
I don't know these front loaders so well but, here's a couple of things to look for.
1) If belt driven, look for the spring loaded tensioner. Once tension is released, check the pully & see if it has excessive play.
2) Check the gasket on front panel & see if drum has rubbed thru it in order to make metal to metal contact.
3) There is alot of pressure on that rear bearing...make sure it's not egg shaped or scored on the inside.
If all else fails, shotgun it (in other words, replace those moving parts you suspect:)
Nov 15, 2013 | Maytag Washing Machines
Model mah4000aww
Sounds like the main bearing on the back of the drum assembly has gone and needs replacing, the drum has moved out of alignment or the electric motor has burnt out. Best to have a Maytag repair tech or someone who is qualified to look at it.
Nov 05, 2012 | Maytag Washing Machines
Maytag MAH4000AWW no longer does the high speed spin cycle. Other than that motor runs fine. Seems like a controller issue but don't have a repair manual to know for sure.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-MAH4000AWW/3048/0153200/M0603006/00013?blt=06&prst=0&shdMod=MAH4000AWW
It could be the motor control board not telling the motor to switch to its highest speed, but it could also be control board not telling the motor control board to activate, but it could also be in the timing circuit. What other indications are you getting? Take a look at the wiring diagrams for this machine on the referenced site.
Jul 01, 2011 | Maytag Washing Machines
On my maytag neptune model # mah4000aww the spin cycle is extremely loud and I recently noticed that midway thru the cylce there must be a leak as a small amount of water is on the floor under the front...
Hello, it sounds like your Neptune's bearings and seal need replaced... See NeptuneBearing for more info on replacing your bearings and renting the special tool kit to save you time.
I see that you have a MAH4000 Neptune. Did you know that your machine shipped with a faulty door latch wax motor that will eventually damage the control board? See NeptuneHelpSong for a video that explains what happens when it fails. You can proactively upgrade your wax motor before it fails and prevent the failure to the control board.
I hope this helps...
Apr 20, 2011 | Maytag Neptune Washer
MY NEPTUNE WASHER IS MAKING NOISE DURING SPIN CYCLE WHAT PART DO NEED TO REPLACE? MODEL # MAH4000AWW
If the noise starts before the drum starts to turn it might be the pump is obstructed. If it starts soon as the drum starts to turn then might be the drum bearing. If it is a knocking vibrating sound open the door and grasp inner drum try moving up and down and side to side . If there is any movement aside from the whole mechanism then the spider that holds the shaft to the drum is broken . Need a tech
Nov 23, 2010 | Maytag Washing Machines
The bearings in the Maytag Neptune MAH4000AWW washer are wearing badly. Sounds like a jet in my house when it spins. Can the bearings be replaced without replacing the outer tub?
If you think that there is no shake or play in the bearings a good wash with kerosene or diesel will take away all the dirt that causes the noise. The use light grease/heavy oil (90) to fill into the bearings.
Tip: repeat the washing with the diesel, use a good small brush and hold a tray under to pour the diesel and collect on to the tray till the noise subsides.
However if the bearings are still noisy then I think you need not replace the drum .
If Helpful credit me for the tip.
Aug 20, 2010 | Maytag Washing Machines
Need to replace drum bearings on maytag mah4000aww washer
I will be very happy to assist you in this issue.
please follow this web side
http://appliancejunk.com/forums/index.php?topic=5233.msg21522#msg21522
Was this helpful?
i hope this answer your question
your rating and comment its very important to me
thank you
Nov 14, 2009 | Washing Machines
Neptune washer
Why?Do you understand that the bearings are locked into the outer tub and you have to replace that,the outer tub.Very expensive repair that will most likely be almost half the price you had paid for the machine new.My advise is DONT FIX this if you have a bearing problem ,because I honestly believe in letting the customer know the truth.Sorry, but a 15 year old re- conditioned Maytag will out last any Neptune ever made.
Apr 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
328 people viewed this question
Top Washing Machines Experts
