Question about Avanti Microwave Refrigerator
Does leaving handset in charger shorten battery life
    Scholar:
  • 57 Answers
I used to repair pagers for Motorola and back then the biggest problem we had was from bad batteries. Firemen would go on vacation and leave there pagers in the chargers while gone. They would return in a week or two and find that there pagers would not work. The chargers heat the battery while charging and this continued heating after charging would ruin the batteries. New chargers aren't as bad but it is best to cycle your battery. Run it until it needs charging, charge until charged then use until it again needs to be charged. Refrain from unnecessary charging. If you properly cycle a battery it can last for 2 or 3 years before replacing
Posted on Oct 07, 2009
Does leaving bocsh cordless drill battery charging over the weekend a problem
Only if the charger does not stop charging.. over charging will shorten battery life!!!
Mar 10, 2017 | Drills
How long does it take to charge
Usually overnight, and keep it plugged into the charger whenever you can. Don't worry about advice that says you should drain your battery once in awhile. That hasn't been true for over 10 years; batteries and chargers have changed since then.
Draining your battery will actually shorten it's life. All modern chargers shut off completely when the battery is fully charged, therefore no power is wasted by leaving it plugged in. There is no additional fire hazard from doing this either, which is extremely rare in all cases.
Feb 11, 2017 | Cell Phones
Bdcs50, can it be leaft on the charger althe time, or this hurt the battery life?
NO, unless the battery charger is a "tender" type...(its not).... I would NOT leave it on charge, it will shorten the life!
Jan 18, 2017 | Drills
Has been charging for 3 days but does not reach full charge. Now appears to be draining when plugged into charger
Sounds like a faulty charger.have you tried using another charger.have you also tried running the battery completely flat via control panel utilities.sometimes this helps the battery renew its stamina by complete discharge then doing full recharge.lastly if the charger is not faulty and you have tried full discharge and recharge cycle it could be the battery is starting to fail.it is not a good idea to leave the battery on continual charge as this can shorten its life.most batteries last between 500 to 700 recharge cycles before they start to lose their holding capacity.
Feb 01, 2016 | Computers & Internet
Does leaving my camera on the charger kill the battery?
Hey there,
The answer is yes. The life of your battery is shortened every time you charge it. If you leave it on the charger, it will stop charging when full, but constantly attempt to top it up to full charge.
The best way to extend the life of your battery is to charge once the battery is near depleted.
Oct 03, 2013 | Nikon COOLPIX L6 Compact Digital Camera...
I have a GE model 25836CE-B cordless phone. My problem is this: when the phone is off the charger base, after a few minutes it will keep on beeping even if no one pressed the paging button at the charger...
Actually, you can't overcharge the battery. The base is designed to hold the handset indefinitely. Once the battery is charged it doesn't do any damage. You probably just don't have the battery charged enough to use the phone. Leave the handset on the base overnight, let the thing charge, and it should work properly.
Jul 12, 2011 | Uniden Cordless Phone
Acer aspire 5520 wont power up.. no charging light when connected to mains
Try another charger. If it turns on and chargers the unit you are currently using needs to be replaced. Do not leave your charger plugged in after charging your battery as this will shorten its life.
I’m happy to help further over the phone at https://www.6ya.com/expert/walter_628d4d23d01fb34d
Oct 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
Motorola CP040 charging time
The rapid rate charger WPLN41__ will typically charge a battery in 90-120 minutes. Your battery should be depleted or nearly depleted when you place it in the charging stand. Be certain your radio is always turned off, when charging an attached battery. The NiMH battery will generally go 12-16 hours on a charge when new. If you work an eight hour shift, you might see if the radio will go 2 days on a charge. Later as the battery ages, you will need to charge it nightly. (Think of putting it in the charger as putting it to bed at night.)
Rapid charging is necessary on NiMH and Li-Ion batteries. They require a "hotter" charger, a fast rate, to completely charge the battery. It will not harm this chemistry of battery. It is safe to leave the battery on the charger overnight, or for a weekend. We would not recommend leaving the battery on the charger longer periods of time, as that will age the battery and reduce its life.
(Sidenote: Frequent rapid charging will however reduce the life of a NiCD battery.)
Aug 12, 2009 | Motorola Radio Communications
Dangers of a Motorola being left on when charging in a multilpe
Don't know if you'd call it dangerous, but wisedom would be not to leave a radio turned on while on the charger. 1) Shortened battery life due to short charging. The battery will never be fully charged due to powering the radio. 2) Inadvertently pressing the PTT button while the radio on the charger can/will burn out components in the radio including the PA (final amp) which is a costly repair.
Instead of leaving the radio turned on while on the charger, buy a second battery to keep on the charger. Then you only need to swap batteries. Your radio would be able to remain on, and never be on the charger.
Jun 28, 2009 | Motorola Radio Communications
Avanti Microwave Refrigerator Logo
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
