Question about Tascam CD-A500 CD Player
Tascam CD-A500 'no disk' problem
My Tascam CD-A500 was working - then the other day, I put a CD in and it said 'no disk' - tried several other CDs - same thing, I keep getting the message 'no disk'. Is there anything else I might try before checking on getting it serviced? Thanks!
  • 1 more comment
  • radar166
    radar166 Jun 23, 2008
    I have the same "no disc" problem with my CDA500. How do I change the lens or is it worth the time and cost?
  • Anonymous Oct 15, 2008
    have the same problem but some other CD play OK. So I guess many people have the same problem... getting a new one..
  • wvonstockhau
    wvonstockhau Jan 25, 2012
    I had the same problem and found out that it only happened with CD's which was not of the required thickness of CD (Google Redbook CD) Other CD of correct thickness will work.
How hard is it to replace optical lens on the Tascam CD-A500?
Posted on Oct 14, 2008
  • 107 Answers
Try to listen to sound inside if the any motor is working through the disc tray. then try to open it (if you want though) then observe it.
after that if the motors are ok, try to adjust your optical lens variable risistor.
note if the optical lens is not emitting a red light your optical lens is the problem, changing it is the only solution.
Posted on Jan 30, 2008
Tascam cd -rw 900 sl wont play cd burnt from my laptop
Make sure you are burning the audio files in a format it can read. The standered is Mp3, but some times you need to burn them in other formats.
Apr 05, 2014 | Tascam CD-A500 CD Player
Can i use any type of blank cd format i.e. MAXELL,TDK,SONY cd/cdr/cdrw. On a TASCAM CD-RW5000 or Do it just take the DIGITAL AUDIO/COMSUMER TYPE ?
What does the instruction manual say about what to use?
Personally I buy Taiyo Yuden and have never had a problem. In Radio we used a lot of CDRW900 units and they used them many times a day using standard data discs. Name brand discs like Maxell and the rest are there for profit- they don't make discs so they do not regulate the quality. Go to and read up on media quality and you will end up with what I use.
Aug 13, 2012 | Audio Players & Recorders
Hi, I have a Tascam CD-A500 combo CDplayer/cassette recorder. The CD player has started skipping with very minimal vibration. This is new and never had these problems before. It is the most sensitive when...
Laser assembly is losing its ability to properly focus on the disk surface. It is going to La La land and needs to be replaced.
Get another player since repair is not cost effective.
Mar 19, 2017 | Tascam CD-A500 CD Player
CD player does not recognise some CDs. When placed in the drawer the deck displays "no disc" if another CD player is used the disc works fine
I have two of these Tascam CD-A500 players, and one more than the other has this problem of not reading some CDs that will play fine in other players. I'm starting to loose faith in this Tascam product. Anyway, seems the consensus is to open it up and check for dirty laser optics. If that doesn't fix the problem, then send it in for repair or scrap it and buy a different brand. I've not had this problem with any other brand CD player, but very suspicious that the same problem happens on BOTH of my Tascam CD-A500 units.
Nov 15, 2009 | Tascam CD-A500 CD Player
TASCAM CD-A500 - No Volum Control Switch
You control the volume by the amplifier or receiver that you plugged the tascam into. The only volume control on the tascam appears to be for headphones, the other volume control is for recording gain input.
Jan 30, 2009 | Tascam CDa500 CD/Cassette Combination...
Replace Tascam DP-01FX/CD -- the CD R/W won't work
I don't think there is a problem with your CD writer.  You have not inserted the type of disc your write drive requires.  You must use a BLANK "AUDIO CD-R".   Check your instruction manual concerning the type of disc required.  Data CD-R's will not work in this type of drive.  if the disc has "DATA CD-R" or "700"mb or "800mb" printed on it it will not work.  audio CD-R's are not as common and are a bit more costly.   They are the only type of disc that will RECORD in your drive.  Regular audio CDs should play in your drive.  I hope this solution will work for you and I wish you every success! Michael Mittelsdorf
Nov 03, 2008 | Tascam DP01 All-In-One Recording Package...
There is one of two things that is wrong with it..
1 the laser lens is dirty and needs to be cleaned witch you can fine a laser lens cleaner at your local radio shack.
2 the laser lens could have been bumped off the track so is that is the case you will have to poen it up and use something soft like a Que tip and gently nudge it.
Oct 15, 2008 | Tascam CD-A500 CD Player
Cd player reads disc error
maybe you need to change the optical eye now.
but first try to adjust the variable resistor/trimpot resistor.
try this options to your player.
if using a cd/vcd/dvd products, we only should play a cd/vcd/dvd dics without a bad scratches. the scratches are making the optical eye worn-out easily.
Jan 28, 2008 | Tascam CD-A500 CD Player
Tascam CD-450
re shock mount it in case blow out all the dust
Jan 14, 2008 | Tascam CD-450 CD Player
Tascam CD-A500 CD Player Logo
775 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
