Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
How can we avoid the odor that we usually have with other vac exhausts? will cleaning the filters as suggested really keep that from happening?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Bagless vacuums have a real problem with bacterial growth. That is what produces the odor you are smelling. Wash the cup in an enzyme and the filters too if they are the washable type. Make sure everything is dry before you reassemble the vac. Then turn on the vac and pull the hose out like you would be using the tools. Holding the hose end that has the suction, spray a small burst of Lysol Spray into the hose opening so the vacuum "sucks" the Lysol through it's interior. This will kill the bacteria in the hose and the plastic housing of your vacuum. Usually 3 bursts works fine. If you spray too much and get your machine "wet" with the lysol you could damage your motor so small bursts are better than a long spraying action
Posted on Oct 09, 2009
How to use Shop Vac 85L450 exhaust as blower
Unlike the old days few vacs today have a blower facility.
In the old days many vacs used a single exhaust port the hose could fit into for blowing and in particular using some of the supplied accessories - such as the famous spray gun loved and hated by everyone in equal measure.
Modern vacs tend to have a diffused exhaust usually through several ports, perhaps because of imagined safety concerns. I suggest you check the operator instructions.
Jun 24, 2014 | Shop Vac Vacuums
Loss of suction power & exhaust coming out of vents beneath exhaust port w/ barely/if any air pressure out of port itsef.
You should find your user manual, look up the phone number for Shop Vac's customer service and call them. They will be very helpful and with the unit being no older than that, it should still be in warranty. They will probably have you send it back and will possibly just send you a whole new unit.
Nov 11, 2013 | Shop Vac Shop-Vac 905-65-00 1-1/4" by 8...
Motor housing is hot
This model has 2 side filters, check and clean those. Be aware that this is a quick clean vac, not to be used for extended periods of time to replace a full size upright. clean the inside filter in the dirt cup.
Apr 16, 2010 | Hoover S2220 Flair Bagless Upright Vacuum
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
Feb 27, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Nilfisk Family Vacuum - Strong Awful Odor
Not sure what a bacteria smell is perhaps you mean a mildew type smell.
If you have picked up something wet, start at the front of the vac and work your way to the exhaust.Change the front most filter first. Baking soda may help to eliminate some of the odor.
Personally as an allergy suffer, which you may be given the Brand I would remove all and let them and the tank air outside. Meanwhile install a fresh set.
Sep 13, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Hi, I have a canister Kenmore vacuum with power head. Everytime I use it, it smells sour. Its strong and like FEET with bad odor. My old Kenmore did the same thing but I used it anyway...because the power...
Never heard of this odor but if you have had it in both vacs it might have something to do with a disintegrating rubber backing on a carpet.
Arm and Hammer makes a baking soda based vac powder that will help eliminate some odors.
Do several things , get the powder and pour a tablespoon of it or baking soda into a fresh bag. Keep your filters fresh. If you use washable filters be certain they are thoroughly dry before reinstalling. And use a Mutli ply filter bag.. and NEVER pick up anything wet or vacuum a damp carpet
Sep 10, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Deodorizing the vacuum
First of all Clean out the vacum cleaner . Empty canister and take filter outside and hit on something to get all dust out . Now wash canister and filter with vinegar water and let dry before using vacum again. You might try using carpet fresh for pet odors on carpet and empty and clean canister and filter regularly. I own a cleaning business and this is a hard problem to solve with all vac. cleaners. Good Luck!!
Jan 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum cleaner smell
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=528723
Posted by lcw1 on Apr 20, 2008
Our Hoover Windtunnel has recently started emitting a bad odor when we use it. We recently bought a new house, and the previous owners had dogs, but the carpet was professionally cleaned before we moved in. I have replaced all of the filters and belts to no avail. At this point, I have to remove and rinse off all of the filters after every time I use the vacuum to prevent stinking up the entire house. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6616-900 Windtunnel Bagless Upright
I think you are right, if it is not the switch then it would be the motor. Does it smell bad like a burning smell? If so it is definitely the motor and then @ that point you may want to get an estimate for motor replacement, and keep in mind of what you spent on the vacuum versus what the cost of repair might be. My own rule of thumb is if it cost more than ½ of the price I paid for it then you have to decide – do I want to pay the repaired cost for the vacuum or do I want to purchase a new one. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Hoover U6616-900 WindTunnel Bagless...
Dog smell after cleaning
This is an inherent problem with bagless vacuums. The filter(s) will absorb odors and odors will get trapped in places that you cannot clean. This is why I always recommend bagged units. They are easier to clean and the odors go out with the bag. About the only thing you can do is put a deodorizer in the machine and keep the filter clean. Be careful not to use petroleum based deodorizers as they can affect the plastic.
Feb 17, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Shop Vac Model 758.17871
I would suggest it if it gets dirty muddy you can always clean the filter alot easier than replaceing vac
Dec 21, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
123 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
