Question about Compaq Armada E500 Notebook
1- i push the "turn on" button 2- the machine starts loading (booting) 3- the "compaq red logo" pops on the screen 4- after a few seconds the screen flashes 5- the machine goes back to (1) and does this loop over again, and over again , and over again
    Scholar:
  • 89 Answers
Sounds to me like the BIOS (software that is loading when you see the compaq logo) is not detecting your hard drive. Normally in this case, the BIOS will say something like "no bootable drive detected" or "invalid boot device" or " ...... is corrupted or could not be located" (where ........ is a file that windows needs to load).
You can try using a program called Killdisk, to erase the hard drive so windows setup can re-label the drive with a new MBR (Master Boot Record). Re-labeling this can sometimes help your BIOS re-detect your HD.
Download and run only if you are not worried about losing any data off the disc. It can NEVER be recovered after running this program.
http://killdisk.com/downloadfree.htm
let me know if you have any questions running this program.
Thanks and Happy Computing!
Posted on Oct 07, 2009
    President:
  • 2,600 Answers
Try this...it works most of the time...this is for windows xp, if you have Vista all you have to do is boot off the cd, let windows load, click on your operating system (it will be the only one listed) click repair, when it is finished....reboot, take cd out.
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
I cant get my phone to turn on everytime I hold the reset button the apple logo appears for 5 secs then the screen turns black.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 30, 2010 | Apple iPhone 3G
My Iphone 3G is not turning it has the apple sing in the middle of the screen and stay like that, I did not drop it in into water or anything like that ... what can I do?
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Nov 12, 2010 | Apple iPhone Smartphone
Iphone 3GS- only get the apple loading screen.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Nov 29, 2009 | Apple iPhone 3G
My iphone wont load up i did a reset on the phone to factory settings and now when it cuts on its stuck on the apple logo
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Sep 23, 2009 | Apple iPhone 3G
My phone is dead
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Sep 06, 2009 | Apple iPhone Smartphone
Phone doesn't power on
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Aug 12, 2009 | Apple iPhone Smartphone
Iphone wont turn off after reset.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Aug 12, 2009 | Motorola Mobility ROKR E6 Smartphone
Msdc mount error appear eveytime i click on files
Try these resets:
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Aug 02, 2009 | Apple iPhone Smartphone
Lcd
try rsetting the iPhone:
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Jul 24, 2009 | Apple iPhone Smartphone
Screen is all white
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 24, 2009 | Apple iPhone 3G
Compaq Armada E500 Notebook Logo
143 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
