Question about Xerox XC356 Copier
Paper won't go through xerox
I've taken out the toner and drum cartridge and inserted a manila file folder per instructions from my xerox xc580 manual. The paper will not pull through and seems to get caught on the left side before going down into the black roller which I guess hardens the ink. I can't find any pieces of paper jammed and nothing seems out of place.
    Guru:
  • 389 Answers
Under rubber roller of the presenting the paper is located brake platform. Check as she works. This often can be that paper pulls not exactly. Follows to restore the brake platform. Good luck.
Posted on Oct 08, 2009
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
HOW CAN I SOLVE "THE TONER IS NOT SET INSERT THE TONER" ERROR ON MF3220 CANON, I've checked the sensor and cartridge gears.
TAke out the cartridge and unplug it and plug it back in and put the cartridge back in and see if thats the problem for you.
Dec 29, 2012 | Office Equipment & Supplies
Xerox 3550 toner install
Replace the print cartridge using the following instructions:
1. Release both latches on the side of the front door and open the door.
2. Pull the print cartridge out.
3. Remove the new print cartridge from its bag.
4. Slowly shake the cartridge five or six times to distribute the toner evenly inside the cartridge. It will provide maximum copies per cartridge.
Note: If toner gets on your clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
CAUTION: Do not touch the green underside of the print cartridge. Use the handle on the cartridge to avoid touching this area.
5. Hold the print cartridge by the handle and slowly insert the cartridge into the opening in the machine.
6. Tabs on the sides of the cartridge and corresponding grooves within the machine will guide the cartridge into the correct position until it locks into place completely.
7. Close the front door. Make sure that the cover is securely closed.
Nov 22, 2012 | Xerox 3550 AllInOne Laser Printer
My Brother HL 4040cn printer is leaking toner, black and yellow. It leaves spatter spots of these colors on printed pages. The machine does not have any messages. Do you know what this may be from or how...
If you've taken the printer apart and cleaned the belt unit and everywhere else in the paper's path, then it is probably either a bad toner cartridge or the drum. Since it's multiple colors producing splatter, its most likely the drum unit. Try taking the drum out and removing all of the toner cartridges and then clean the drums and corona wires. If its still producing splatter afterward, you've got yourself a bad drum.
Jul 20, 2011 | Office Equipment & Supplies
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
Copies come out black
Doesn't worth it, you need to replace the drum unit.
Mar 26, 2009 | Office Equipment & Supplies
Photocopier prints black lines on one side of the page.
what copier is it? please specify brand and model? line is usually either created by main charger or cleaning blade
Mar 18, 2009 | Xerox Office Equipment & Supplies
Clicking noise from toner drum
get the toner cartidge out click in the top many times and then check it many times in horizontal leve (move it quickly from right to left many times)this will mix the toner.- reinstall it again.l
Mar 05, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
Xerox XC356 Copier Logo
97 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
