Westinghouse LTV-32w1 32 in. HDTV-Ready LCD Television
Problem for Westinghouse LTV-32w1 32 in. HDTV-Ready LCD Television
I am having problems with my Westinghouse LCD TV.
By cnagel47 on Oct 07, 2009
I am having problems with my Westinghouse LCD TV. When i 1st turn it on, everything is fine but after a couple minutes I lose picture. The audio is fine and continues on. I unplug the tv from the outlet and plug it in to get a picture again but after a couple minutes the same problem occurs. What is wrong with my tv? Any quick fixes?
Best Solution
posted on Oct 07, 2009
Very Helpful)
robo_geek
Rank: Guru  Televisions & Videos  Expert
Rating: 92%, 46 votes
No quick fixes. A component such as a capacitor is heating up and failing. Sometimes a cracked solder connection will work fine until it heats up and no longer sustains the connection.
When the screen goes off, shine a very bright flashlight at the screen to see if the image is still there. In many cases, the problem is the screen backlight, which consists of several CCFL tubes (fluorescent lamps) and a circuit board called the inverter (similar to a lamp ballast).
If the image is there, but the backlight is off, then you just may need a new inverter board.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Westinghouse LTV-32w1 32 in.
Questions and Unsolved Problems for Westinghouse LTV-32w1 32 in.
Do you recommend Westinghouse LTV-32w1 32 in. HDTV-Ready LCD Television?
Answer
Answer
i have a Westinghouse 32'' HDTV model # W3223. recently when i turn it on the volume will... (More)
Answer
I have a tv model no LTV-20v2 SL type no SLT20A only have sound but not Imagen since last night
Answer
I have only colored lines, i can hear the sound but have lines
Answer
my television has colored lines going up and down the screen. i can hear the show just can't see it.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Westinghouse LTV-32w1 32 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
