Question about Kyocera KM-1505 Copier
KM 1505 copier machine
While switching on the machine it shows OP. What is the solution for it. I am first time using the amchine,
Rohan
  • R Rohan Dec 24, 2007
    Rohan
I suggest he waits a bit change the paper tray he is using ,as in use the side way but if the problem goes with both the trays then he should seek further assistance from a qualified person to configure the machine well or he should follow the operations manual book for clues to rectify the problem as it may be just a simple command thats he is not reaching for the machine to work as it is not commanded in the rightful way
Posted on Dec 25, 2007
What happen when kyocera KM-1505 is bringing error code J98
There's probably a time piece of paper or something blocking a sensor or pressing down on an actuator or something
try checking this then do a good clean of the unit.
Jan 16, 2015 | Kyocera Mita Km 1810 1510 1505 Copier Drum...
Dirty and light copy of my Kyucera KM 1505 copier machine
Clean the optical parts (lens,mirrors),and the poligon motor mirrors.
Apr 08, 2013 | Kyocera Mita Office Equipment & Supplies
I've problem c6 400 and whene i press Clear it shows 412 024 on the screen help me
enter service mode by pressing 10871087 then press start button(green) four times.machine will restart and code will go.better check ur power supply for low voltage or fluctuation
Jul 31, 2011 | Kyocera KM-1505 Copier
Ok i have a copy machine is Kyocera km 1505 is appear code Ap i put new toner and is the same what can i do
try to put direct toner in the developing unit then restart the machine if problem still persist try to replaced your developer
Apr 11, 2011 | Kyocera KM-1505 Copier
When am try to get phoyocopy from KM 1500 kyocera machine its showing in display meter as an J 111
you have a paper jam in your copier... open it up and search.. best I can tell you...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Oct 07, 2009 | Kyocera KM-1505 Copier
What is C 710 error codes?
You machine toner is empty insert toner
Jun 14, 2009 | Kyocera KM-1505 Copier
OP error
Have you added toner recently?? If the copier is just running and then shows code you may have to install a new toner. The soft ware is different in different contries and the codes are all not the same meaning. I would cheak the toner first..
Apr 14, 2009 | Kyocera KM-1505 Copier
OP error
OP stands for open door. Either the front door is open or a side door is open.
Hope this helps.
Jan 26, 2008 | Kyocera KM-1505 Copier
Km-1505
THE MACHINE DISPLAY CODE J98
Oct 26, 2007 | Kyocera KM-1505 Copier
Kyocera KM-1505 Copier Logo
54 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
