Question about Maytag Dishwashers
My Magtag MDB-9 Dishwasher the door does not slowly come down, it acts like the spring in it is broke. Could this be replaced?
  • 3 Answers
I recently had a similar problem and after looking around the web I found a site called Appliance Art (http://www.applianceart.com). They have a dishwasher covers that look like stainless but were cheaper than actual stainless. I'm happy with the result, it might be what you're looking for,
Posted on Oct 07, 2009
Why does door open too far and is not horizontal to the floor when open?
Besides spring streaches out over time or one rope breaks. Their are like three spots to hook spring to get tension for door. I just replaces both ropes as one broke and hooked springs in middle hole. Takes more time to pull washer out then to replace the ropes
Oct 31, 2015 | LG LDF6810ST Stainless Steel Built-in...
Door doesn't open slowly, it drops down suddenly when opened. What is the problem please?
Pull the dishwasher out. You may see the mechanism and possibly broken spring or other part. (possible it's just come apart. You may need to remove side panels to see this mechanism for the door (counter balance) .
Apr 11, 2015 | Dishwashers
How do i fix a broken spring on a dishwasher door
You will need to pull the dishwasher out about 12" to 18" to be able to get to the springs & rope links. Many dishwashers use a "rope link" to connect between the spring and the door hinge; and in others, the door springs connect directly to the door hinges. Once you pull the dishwasher out, you will easily see what broke and what you need to fixe it.
Jan 20, 2015 | Frigidaire Dishwashers
My magic chef dishwasher door springs broke. I need to know how to access the bottom of the dishwasher to replace the broken parts.
Open the back door and see whether the hooking points visible.
Look from the front end also to get an idea!
May 21, 2010 | Dishwashers
Kitchenaid dishwasher KUDK02CRBS the spring on the door broke? Is this a easy fix, where do you access the spring
Turn off the power to the dishwasher.
Remove the access cover on the bottom front of the dishwasher.
Lying on the floor,you can see the door hinges and replace the spring.
Feb 12, 2010 | KitchenAid 24 in. KUDK02CRBS Stainless...
I have a KitchenAid dishwasher. The door drops
either the door springs are broke,worn out or possibly the door balancers need replacing
Jan 10, 2010 | Dishwashers
Door is broken
Hello Hickin! It would appear that one, or both of the door springs which act as a counter-balance for the weight of the door, have broke.
To confirm this and get at the spring(s), close and lock the wash compartment door and use a screwdriver (might be a 1/4" or 5/16" nut driver instead) to remove the lower panel.
Once you have the lower panel off, you should be able to see the door springs on each side. You'll probably also see part of the broken spring lying in there too. If the door spring broke near the end by the hook, it is possible to TEMPORARYILY bend the spring with a set of channel locks and pliers to form a new hook end, that you can attach to the door clip. If the spring is broke near the middle, you'll need to get a new one.
Regardless, you'll need to locate the model number for your dishwasher and obtain a replacement spring ASAP, as the temporary repair will only work for a short while before the spring breaks again.
You might want to try Fagor at their site to see what the part number for the replacement spring is. http://www.fagoramerica.com/
The other option with your model number is to try the Sears part web site, which shows a line drawing and parts list for most applianances.
http://www.searspartsdirect.com/partsdirect/index.action
This repair is relatively easy for anyone to undertake and you can save yourself the cost for a service tech's labor charges, plus the trip/house charge they normally tack on.
I hope you find this Very Helpful and best regards!
Oct 12, 2009 | Fagor Dishwashers
Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Jan 19, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Door spring on dishwasher broke
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
Nov 23, 2008 | Jenn-Air 24 in. JDB8910 Built-in...
Dishwasher problems
Can't say for certain, as you don't list a brand or model number, but most have the springs on each side of the outer tub. (you will have to pull dishwasher at least partway out of the cabinet to access them) Some have a set of springs behind the access / toe kick panel. (DW removal unnecessary for these)
Sep 01, 2008 | Dishwashers
Dishwashers Logo
75 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
