Question about Watches
I need to put an extra hole in my watch band because it does not fit.What way can I do this at home,if any
  • 5,568 Answers
The best way would be to buy an inexpensive leather 'punch' at an arts and crafts store. They aren't expensive (Asian stuff) and have 5-6 punches of different sizes on a rotating drum and produce a clean hole. I've found other uses for them as well.
Posted on Oct 07, 2009
Testimonial: "Sounds like a good idea,I will do that"
I want to change the watch strap, mine is brokem
Probably don't need special order band. Most people buy band that is same width. Bands have a collapsible post on each side where they attach to the watch, you just pick a band that fits the width. To change a watch band you have to use something like a razor blade (single edge common to cleaning) to wedge between the metal frame of the watch and the band, then try to get some friction on the post and push it away from the watch and toward the middle of band such that you collapse the post and get it out of one hole that the post is in (2 holes 1 on each side of post) so you can tilt the post out. A new band usually has 2 posts included since it is common to bend the old posts getting them out and hard to just buy those. Put the post in the band, put one end of post into a hole, then tilt and compress with the razor to push post into position, then slide the razor out which allows it to go in the second hole. Now band stays attached.
Jan 10, 2012 | Adidas Adistar ADP1786 WW Watch for Men
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
I have bought citizen watch JR3080-51L , and I need some more links because I got a watch that is good for 7" wrist and I need 8.5" wrist. Thanks
I've had to get extra links before, especially for ladies SS and gold bands. Sometimes a local dealer will have spares that will fit your watch. But, the best source I've found is Ebay. Let me know if you have the stock band or something else. I'll try to help you locate some extra links, or another replacement band at a modest cost. Thanks, Bill
Sep 06, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    I have a problem putting the band back on a tissot 1853 watch. The pins will not align with the holes is there some trick to this that i cant figure out or are the arms bent on the watch?? Need help...
    mcdevito75 here, It"s areal pain but you just have to hang in and keep trying. Postion the band and pins as you can for easy assembly. If you give up see a small watch repair shop in your area, take a break while trying to fit the band if you get aggrivated.
    Jun 19, 2010 | Watches
    How do you put the back, back onto this fs1? The band keeps getting in the way! Back came off easily enough, popped off after unscrewed. Band is still on watch, have tried to slide back into grooves but...
    You have to remove band in order to fit caseback back onto the watch. Insert pocket knife blade between band and case lug and pry inwards. This motion should release the band. It will be a lot more difficult to fit the band back on and you will probably need to buy springbar tool. Rate me plz.
    Mar 03, 2010 | Polar FS1 Unisex Heart Rate Monitor Watch
    Need new watch band for tag heuer watch the one i have is too small. how much is it to replace a watchand
    TAG HEUER watch bands are costly. Over here in England they cost from £60 to £250 (depends on type, model, e.t.c.), but can rocket sky high if you have one of expensive models.
    I would suggest to add a few links to your existing band. This will be cheaper than to buy completely new band.
    Visit your nearest watch repair store and ask how to do that. Watchmaker should be able to order extra links and fit them for you.
    If you insist on a new band - ask watchmaker to order it and fit to your watch.
    Rate me, please.
    Aug 13, 2009 | Samsung Watches
    How do i change watchband for casio bg169wh
    Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Watch band links.
    you would have to either have custom links made or buy a whole new band to be made the links pop out by pins and then shortened placed this way back together
    but if you dont have extra links buying longer band is your better sollution cause creating a link or 2 to fits can be costly
    Jun 10, 2008 | Seiko SXGL61 Wrist Watch
    Watches Logo
    670 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
