Question about NRS 1x/5x Fogless Shower Mirror - Surround Light Free S&h
I have a 240v ballast from china for a mirror light c/w 8w t5 lamp it has input terminals clearly marked but it has four output terminals with a diagram of both pair of wires form each end of the lamp.i got a dc supply from the terminals and the ballast output is marked as 35ma 8w.mirror wiring has a flex from each end of the lamp with the brown and blue linked through via a pull switch.the mirror has a 240v sticker on the back but when i applied 240v to the light taking the ballast out it blew the 3a fuse in the spur.
I worked it out myself in the end
Posted on Oct 08, 2009
Can the charger be plugged into 240V AC
On a light switch or dimmer? Hell no!
You can't plug anything into 240 volts AC unless it is a 240 volts appliance. The exception is dual voltage chargers and these will be clearly marked albeit in tiny text on the charger itself.
It will say something like;
Input 100 to 220 volts AC - Output 5 volts DC - 200 MA.
Jan 04, 2016 | Electrical Supplies
Interior lights
This is both a courtesy and safety issue on many high end vehicles. The light from the interior lights can cast enough light to get to front door and possibly show dangers in your path. And after first getting into you car and starting it, you can check the back seat for any unwanted hitchhikers. As for the 10 minute timer, I don't know if this can be adjusted. A Chiltons/Haynes repair manual for you car may have that answer, or, the Buick dealership shop foreman. Best of luck.
May 31, 2015 | 1998 Buick Park Avenue
I want t replace a mb2x40/120 rs ballast with a 120 277v electronic ballast how do i wire it
Rule #1: TURN OFF THE POWER AT THE BREAKER PANEL.
A fluorescent light ballast is a transformer that outputs a higher voltage than the input (120 volts). The electrocution hazard is very real.
Practically all ballasts have a drawing printed on the label. As a master electrician I still need the drawing to install them properly. Electronic ballasts should have a black and white wire for input voltage. The output to the lamps will be some combination of: red, yellow, blue.
The new ballast must also be matched to the type of lamp. Old fluorescent lamps were T12 (refers to the diameter). New lamps are T8 and produce more lumens with lower amperage.
Sep 27, 2014 | Electrical Supplies
Amstrad drx550 sky box connections
Hi Trevor
If you measured 240V at the input side, how about output side did your measure any volts their?
Jan 18, 2014 | Televison & Video
Life fitness t5-0 shuts off
please LUBE the deck belt, see the video attached 2) lube the rollers bearings front+back
2) test the drive belt for loose or crack,
3) test the voltage terminal motor, see my PERSONAL TIPS for help
4) test the output voltage terminal board, if there ARE NOT voltage for input voltage terminal the control board is faulty.
God bless you
Nov 25, 2013 | Life Fitness T5-0 Treadmill
This morning the power went off briefly. When the power came back on, the monitor screen would not light up. All connections are good, and the power light at the bottom left of the monitor turns green...
Go check the backlight inverter lamp, replace if busted.
This can be found when you open the back of your lcd and manage to get access to it.
The backlight inverter lamp is located at the upper and lower part of the screen.
Go check also the inverter board, the one that suppply high voltage to inverter lamp, see if this ballast transformer are not burnt out.
The input voltage of the inverter board is 24vdc the output is 250v ac..The voltage input terminal of the inverter board usually creates a loose solder. Use a soldering iron to resolder them....
This lamps are available online to order at shoppejimmy.com
Feb 09, 2011 | Dell UltraSharp 1907FP 19" LCD Monitor
4 lamp t5 fixture, 1 black wire, 1 white wire, 1 red wire. how do I wire this
Don't forget this is a 240v appliance so it must be fed from a 240v circuit breaker. Once you have a 240v circuit breaker you need to run 12/3 wire with ground from circuit breaker to a box near your fixture. The 12/3 wire with ground will have; 1 black, 1 white, 1 red and a bare ground wire. With the circuit breaker OFF, hook the wires up respectively to the same colors and ground the bare wires togather with a green ground screw in the box. Turn circuit breaker on.
Nov 25, 2010 | Solar Flare Vho T5 4ft 8 Lamp Fluoro Grow...
JVC DLP MOD#HD55G466 what is the voltage from power supply to ballast and into the lamp.I have no voltage to the lamp could it be ballast?
Ballast board gets voltage from power supply connector CN90BL and volts readings are as follows:
Pin-1 = 380V DC
Pin-2 = Ground
Pin-3 = 15V DC
and output of ballast board would be 12,000 volts AC that goes to lamp to generate spark in its electrodes to produce high bright light.
If you get volts on input of ballast board but still lamp does not fire up then ballast board is not working.
Ballast board part number is QAL0765-001 and available with tv-part.com for $125
Hope these info will help you.
Thanks.
Nov 16, 2010 | Televison & Video
Mitsubishi 52525 TV Red Lamp LED
340v should be on power pwb plug PL on the 1 and
5 (GND) pins for the ballast. and the ballast plug CN should also have the 340V with pin 1 of that plug being GND nd pin 3 should have the 340V If the PL plug on the power board is low the power pwb has a problem most likely the doubler circuit. If CN plug voltage is high say 360V the ballast is suspect.
Jan 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Not coming on, lights blink, but nothing happens
First thing to check is the bulb. On the back of the set is a hatch with four black screws. There is a TT symbol on that hatch, open it and you'll see the black lamp housing over the ballast circuit board. Remove the silver screw on the left of the housing and pull the aparatus straight out. It may stick a little, don't be afraid to give it a tug or two. Check the bulb, the part of the filament that burns is inside the glass tube that is near the base of the bulb bowl. If it looks broken or burned. Replace the bulb. Ebay sells them for about $100 or less. I've never had a problem with OSRAM vs Phillps, so whichever. Phillips is better but OSRAM does work too.
Sometimes you buy the bulb with the housing sometimes not. Its pretty easy to replace the bulb. You-tube it. Reverse the dismantle and see if it comes on. If not, we move onto the color wheel and ballast. Email me if this doesn't fix your problem and I'll help you move onto the next step. cfoley@hawaii.rr.com
Good luck.
Apr 20, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
NRS 1x/5x Fogless Shower Mirror - Surround Light Free S&h Logo
Top NRS Home Experts
Donni Steen
john h
Bill Boyd
Are you a NRS Home Expert? Answer questions, earn points and help others
