Question about Sylvania LC370SS8 Television
Sylvania LCD TV Model # LC370SS8 has bad picture on left side of screen 7" wide from end, but goes away after 3-4 mins. The video is gone or messed up on that whole 7" strip, top to bottom. Looks like two 3.5" strips actually. I need to know what board to order do fix this.
  • 1 more comment
  • kingsblue Oct 07, 2009
    When you say LCD controller board, do you mean what some people call the T-con board? This is the little board in the top center with the small ribbon wires to it.
    When you say LCD controller, do you mean the T-Con board?
    If by "LCD Controller board" you mean T-CON board, then I agree with you. Thanks.
  • 3,037 Answers
Half your screen having lines can be a couple of things, one of which you can attempt yourself (well you can try it all, but only one costs zero money).
Being intermittent I would think it is pretty likely a dirty LVDS cable connection which may just need to be reseated and cleaned (we can only hope), or possibly replaced.
Please understand that by opening a TV you are exposing yourself to many dangers. Be sure that the set is un-plugged and keep one hand behind your back whenever possible to avoid a shock through the heart as this CAN KILL YOU. If you have zero electronic experience I would not attempt this repair.
Otherwise, this is a rather simple procedure, and safe if the set is unplugged and you use common electrical sense (which you probably have). Color abnormalities could also be a bad LCD controller, which translates the digital signal into one readable by the panel itself.
Take the back off of the set and find a 30 pin connector (there should only be two or boards not counting the scalar.) Usual orientation for the connection to reseat is the top, middle circuit board. be careful as it is easy to damage.
You could either use contact cleaner (on both ends of course) or you could just reseat it first (I recommend just reseating it without cleaner).
If that doesn't work then it is either the main signal board OR the LCD controller, main board is probably going to be $250 or so, LCD controller about the same if you can find it.
Let me know how this works out.
Benjamin
Posted on Oct 07, 2009
We have half a screen when we turn on TV
Your TV's primary control board may have gone bad and when the TV heats up to a certain tempurature and then it goes back to normal i suggest a new tv but you can order new parts and replace it yourself, if you need parts I can get a list of parts that may fix the TV
Jan 01, 2012 | LG 42LC2D 42 in. LCD HDTV
When I trun on TV (Samsung LN-T4661F 46 In), it start with half scrren dark from Right Side, time goes by being normal screen. I want to know what the problem is.
Samsung made a bad TV, the new part is $1200 I have the same issue. it is a blurred picture from left to right after about 10 min it goes away. (18 month old tv) it is only going to get worse.
Jun 05, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
My Sony BRAVIA KDL-46V3000 Television has messed up colors on left side when first turning it on.....after 5 or 10 mins the picture is normal.. Also without turning on the receiver (only TV) can't select...
This also happened to me and may continue to get worse... If it goes away for a while after warming up, then it is the same problem... The LCD panel is probably going out, when that happens the cost to repair it is more than the tv is worth... If it is in warranty then you can have it replaced or fixed.
Nov 15, 2009 | Sony BRAVIA KDL-46V3000 Television
Samsung DLP 50
check the input board for AVI make sure it is not dusty and that all the connections on the board are good you may have a bad solder point or that board is bad ,also possible video ctrl board
May 31, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Picture is too wide for the screen can`t see all info on program guide on left side
you are viewing in16:9 ratio (widescreen) and your tv is 4:3 you need to change your picture settings in the tv menu
Aug 29, 2008 | Sylvania SRT2232S 32" TV
Picture problem on mitsubishi medallion ws 55819 model....picture convergence messed up on left and right side of screen (center fine)...problem goes away and set "re-adjusts" after it's been turned on for...
Well I have a Mitsubishi WS-65413 65 in. Rear Projection Television and when I power it on in the morning it looks as if the picture on the bottom of the screen is bending and parts of the picture "double up" but like the person above me said after it gets warmed up it goes back to normal but every 3 or 4 hours it might get messed up for a min...Anyways: Is it the picture tube going out?? If so how does anyone know how much it would cost to repair/replace & What is a "Convergence Module"?? I don't know if my T.V has one of those or not but if it doesnt is that the problem perhaps?? Please help me or ill be forced to go outside... :-( ..... thanx 4 the help ppl!! -
- Zachariah-
May 10, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Sylvania LC370SS8 Television Logo
270 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
