Question about GE RM24912 Universal Remote Control
Remote control programing
My remote does not have a setup button so how do i program my 24912b remote?
  • Anonymous Feb 13, 2009
    i get new remote .hoe to use it
  • 934 Answers
Tip
Programming Philips Universal Remote Control To Your Device
Program the Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2. Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3. Release the Setup button
4. Press the button to which you want to programme(TV/VCD/DVD).
5. Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7. If the device responds, you have successfully programmed your Philips universal remote.
8. If the remote is not programmed then, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
1. Turn all of your devices off, and then manually turn on the device you want to program.
6. Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To Get The Programming Codes :
Please go to below website to get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote model.
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
Attached a image for your reference:
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
on Jul 27, 2010 | Televison & Video
What button do I use for a cablebox
You have to setup the remote control to cablebox. If you wish to get more details about the setup proceedings to jumbo universal remote control, check this link. Setup proceedings to some popular model remote controls, including jumbo remote control is given in detail. Pull up older posts there.
Feb 28, 2013 | Innovage Jumbo Remote Control
Programming tv
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
These are the general proceedings to synchronize a universal remote control to a device. If you wish to get more details, check this link. It has setup proceedings and setup codes list to may brands of universal remote controls .
Jan 14, 2013 | Innovage Jumbo Remote Control
UR8050T universal remote programming guide
Find magic button or setup button. Turn on device. Hold down button you would like to program it may blink twice. Punch in 911. Toggle between power and device until device turns off. Hit magic or setup button. Hope this helps
May 19, 2011 | Universal Remote Control Hampton Bay...
How do i program this remote control Radio Shack 6-in-1 Easy Setup Voice Remote Remote Control Easy remote
Turn on the unit to be controlled manually. Press and hold Setup until the voice prompt starts the programming menu. Press 1 to directly enter a code. Press 2 to search for a code. Note at any step if the no buttons are pressed for 15 seconds, the remote will enter the usage mode. Start again from the Setup button. When prompted, press the device button for the device you want the remote to control.
Then enter the 4 digit code (if using the direct programming mode). The LED will blink twice and the remote will announce success. Test if the remote works (play, power) when prompted to test the code and press Setup if it is successful. Then wait until the remote says goodbye and then press Power again. The unit should turn off. (I strongly suggest testing other functions as well after this.) Repeat with other codes if unsuccessful.
For searching through the programmed codes, start as indicated above: press and hold Setup and then press 2. When prompted press the device button. Then press the test key (power usually). Slowly alternate pressing CH+ and power until the device turns off. Press CH- if you miss the device turning off. Press Setup to store the code. Then after the remote says goodbye check if the remote works for all the functions. Repeat the above if it doesn't work for all features.
The manual for the remote is available here: http://files.remotecentral.com/view/852-1041-1/radio_shack_15-2146_6-in-1_easy_setup_voice.html . This file is a PDF in a zip archive and does include the code list at the end.
Please note that codes in the remotes are limited to those for devices released at least 6 months before the remote was programmed. If your device is newer than your remote, you may need a new universal remote. I suspect this remote may be from 2004.
I hope this helps.
Mar 01, 2011 | Radio Shack 15-2146 Remote Control
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • Dec 04, 2010 | Philips Televison & Video
    Need to program my tv and dvd player to the remote
    Please follow the steps below
    Program the First Device by Entering Direct Codes
    2.Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
    3.Release the Setup button
    4.Press the TV button.
    5.Release it immediately and make sure the indicator light is illuminated.
    7.If the device responds, you have successfully programmed your Philips universal remote.
    8.If not, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
    6.Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
    7.When the code works, press the Mute button on the Philips universal remote and the code will be stored.
    To get the universal remote codes please visit below solution
    http://www.fixya.com/support/t5395701-universal_remote_code_phillips
    Thanx
    Jul 27, 2010 | Philips Universal PH301S Remote Control
    Kidz Remote
    RE: Programming a Kidz Remote by Kissel By helpmedave (Guest Post) 1x1.gifthe procedure to program the remote is as follows.
    Find the setup button recessed between tv and cable buttons. Use a toothpick to press the setup button until the led blinks once, keep holding it until it blinks twice then release. press tv or cable button then enter the 3 digit code for the device you want to try. the light will blink twice if the code is valid. ( yeah i know you don't have the codes ) (me neither ) if you successsfully program it to control a device, you can then program each button as follows. hold setup button until light blinks twice.press tv or cable as needed. press 995 the led will blink twice . press the button to program. enter channel number you want (may have to enter 2 or 3 digits 08 008 etc)press setup light will blink once.m select another button and repeat to program all buttons you wish to program.to lock in settings, press setup until led blinks twice. good luck.Posted on 08/09/2007
    Jul 16, 2008 | Televison & Video
    Televison & Video Logo
    123 people viewed this question
    Top GE Televison & Video Experts
    matt martin
    matt martin
    Are you a GE Televison and Video Expert? Answer questions, earn points and help others
