Question about Frigidaire Refrigerators
Broken water actuator broken ice actuator - Frigidaire Refrigerators
    Novelist:
  • 121 Answers
What do u want to know.
Posted on Oct 07, 2009
Ice not dispensing from the freezer door. Water dispenser works fine.
It sound like the switch is not being hit from the actuator. If it is a whirlpool or some Kenmore models then there is a switch bracket that is notorious for breaking the switch mounts. Pop the front frame carefully off usually from the bottom with a putty knife and this should reveal a switch bracket. Other brands will come apart differently.
Apr 21, 2015 | Refrigerators
My ice dispenser quit working
There are multiple components that can cause this.
Open the door and put your finger in the ice tray. Is there any ice or water in it.
If so then the problem is likely the ice maker.
If not then the water supply is either stopped up or the water valve solenoid is broke.
If their is ice then the ice maker may not be making ice for other reasons. Is the Ice Level arm down? If so, the Icemaker has a clock like motor that is actuated by a temperature sensor.
Ice maker calls for water, solenoid fills ice tray, temperature sensor gets cold over about 45 minutes and closes the motor circuit telling the icemaker to dump ice.
If everything is right and still doensn't make ice, some mechanical aspect or the icemaker appears to be broken.
Thanks for using FixYa, Good Luck.
Mar 03, 2011 | GE Refrigerators
I have lsc27926st. The water tube to the ice tray froze and I used a hair dryer to unfreeze it. After the tube was clear the water will not refill the tray. I have turned the on/off switch a couple of...
from the ice freezing tube may have caused valve to burn up on unit... these are normally plastic water valves on back side of unit lower right side... very common problem... i am a lg oem authorized servicer parts usually come from lg electronics in alabama unless you have a local supplier that you can go to...        the ice makers themselves have been problems on these models as well... 1 year warranty is all they give and usually 1 year 2 days they go out...   let me know if i can help anymore    ACHEATINGUNLIMITED@YAHOO.COM         TEXAS BASED APPLIANCE /HEATING AND AIR COMPANY
Dec 31, 2010 | LG 26.0 Cu. Ft. Side-by-Side Refrigerator...
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
No water going to ice maker. Ice maker is calling for water. 10 volts on plug voltage does not change when I hear it turn on
Hi. Sounds as if you are some what familiar with using a meter for testing circuits. Disconnect at least one lead from the water valve coil and Read across the coil checking for resistance. I should read less than 10 Ohms.
From what I read about you only having 10 volts you have a voltage issue as the coil voltage should read in this range 115 / 120 VAC. The 120 VAC is controlled by an actuation arm that is actuated by a cam lobe inside the icemaker front cover. If the actuating arm is bent or broken the icemaker will cycle but the water valve will never be activated with 120VAC to energize the coil for the duration of the icemaker fill cycle.
If your up to it you can make your own test cord from an old extension or power cord with two female bayonet terminal ends and verify the water valve operation.
Connect the locally made by you test cord female terminals to the water valve and BRIEFLY plug in the cord. The water valve should open when you plug in the cord and shut off when you unplug the test cord.
Jan 30, 2010 | Refrigerators
My ice cubes appear to be hollow. what is causing this?
The water valve is not letting enough water in . Replace the water valve .
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice and water dispenser stopped working
Welcome to the computer world. When depressed, the paddle actuates a switch attached to the bracket above. The switch sends a low voltage signal to a small circuit board mouted right behind the display. A computer chip on that small board communicates with another chip on the main control board mounted in the rear wall. Your situation could be a bad actuator switch, a broken paddle tab, possibly a bad door switch (the fresh food doors must be closed to dispense), or a bad electronic control.
Jun 05, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Whirlpool gold refrigerator icemaker leaking water
hi there,
sounds like the ice or water actuator or paddle is broken. purchase a new paddle and replace it.
the reason you have leak is because you have warm air entering through the broken part into the freezer.
can you provide me with the model # and i will send you a part breakdown.
Sep 09, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water Actuator is broken.
I had the same problem with my water dispenser and since they were willing to sell me a part but provided no directions and I couldn't locate any I decided to make my own for those who might need them. Here is a link to a PDF I made, hope it helps.
http://www.rharriman.com/SupportFiles/FridgeActuatorReplacement.pdf
Before starting this job I would also like to warn all to please be save and UNPLUG the fridge. The whole job took me less then 30 minutes and I doubt anything will go bad in that amount of time.
Jan 13, 2007 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
87 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
