Question about IBM ThinkPad 380ED
When i turn on the laptop,it then says error 00161,00301,and 00163 when i say okay it then asks for the time and date,then the sreen goes black and it starts all over again
    President:
  • 2,600 Answers
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Oct 07, 2009
Upon connecting my ThinkPad A21m to the internet and the launching of the browser, the laptop goes into a sleep like state. The screen is black and no words or images can be seen. Moving the mouse does...
The BIOS battery is flat. This battery keeps the Date and time and other settings for the laptop to function correctly. Replace the BIOS battery and then go to the BIOS configuration and set the Date and Time.
If you have further problems, please leave me a comment and give me details of the error messages.
Nov 15, 2010 | IBM ThinkPad A21m 2628 Notebook
Computer turns on, starts up ok... can hear the start up music, hard drive lightworks ok, screen goes black... after 10 mins. when this prob. started.... now it stays on (see the icons) for abt 1 min.- 30...
have you downloaded any new software? it might be the culprit if not try restoring to an earlier date when the system was working properly (like at least 4 wks ago) .. work quick since you only have 1.5 min go to start/all prog/access/systems tools/system restore...note when it shuts down it will boot up auto and you must click okay when prompt
Aug 19, 2010 | HP Pavilion dv9000z Notebook
Windowxp dell 600 lap top will not charge battery or turn on wih ac power do i need a new battery or black sreen does not deytemine ac adapter will not preform best operatings
check first the battery pack... use another batter pack to check the batter if its okay or not... if okay..then use another charger also to check the charger. if the problem is the same you need to open you laptop and check or repair the charger connection or some chips of your unit.
its needed the expert hardware. bring to the nearest computer service center if you can't do it..
Jun 23, 2010 | Dell Latitude D600 Notebook
My sreen is fickering all the time,so bad sometimes the screen goes black,
Sounds like you need a screen replacement. The bulb that provides the backlight to the screen is going / gone bad.
Jan 07, 2010 | HP Pavilion dv9000z Notebook
Just as i turn the power on it says date time error then goes to a black screen and asks for a password ibm r51e
HMM, your kind of screwed I have worked on the thinkpads in my shop b4 and there is no work around the bios password. Either you need to remember your password or get ahold of who you bought it from. IBM has a military contract and they are not allowed to set a backdoor on the thinkpads according to that contract. The only thing they can do is replace the motherboard its a crock but thats the way it is. I would just but buy a new laptop that motherboard is $249 plus labor.
Dec 29, 2009 | IBM ThinkPad R51 Notebook
MY SREEN GOES BLANK(white) WHEN IM ON IT WINDOWS VISTA
my acer aspire 9300-5349 orbi cam show black screen, how can i fix it..
Nov 10, 2009 | Toshiba Satellite A135-S4527 Notebook
Thinkpad R40 find date & time for start-up
Right-click the time in the lower right, select: adjust date and time, select: internet time, select either source, select: apply (if high lighted)--otherwise close. You need to be connected to the internet for the internet time to work.
Sep 18, 2009 | IBM ThinkPad R40 2722 Notebook
Black screen after windows xp screen nothing else
Sometimes the function keys get depressed by accident and it takes away your display. Press the FN+F5 and FN+F6 three times each and see if your display comes back on.
Dec 27, 2008 | Acer Aspire 1640Z Notebook
Ibm think pad 2635 cant do anything. please help
its the bios battrie is dead. simply replace the batt and it will work or just pull the bat set the time and it will restart then you will jsut have to do that every time you start up
Oct 27, 2007 | IBM ThinkPad 380ED
IBM ThinkPad 380ED Logo
172 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
