Question about Garden
120 garden tractor hydrostatic pump.squells when put in gear and it goes backword better than forward
    Problem Solver:
  • 4 Answers
As for the squealing, it could be low on fluid.
It sounds like you need to adjust the control arms going to the hydro unit. I had the reverse problem on a 1650. Just an adjustment made all the difference.
Posted on Oct 09, 2009
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
Craftsman 917273482 will not shift into gear, and I can't push it because it won't disengage
If there is too much play in the drive belt due to belt stretch or linkage wear, the belt will be too loose to drive the tranny but still cause the tranny input shaft to rotate preventing it from being put into gear.
Do the gears grind when trying to put into gear? With engine off you should still be able to push the machine if you put it in neutral. Unless, of course it is a hydrostatic transmission, in which case there should be a lever to push/pull which will put the hydrostat in neutral. This is all assuming that it is a hydro and while running the machine won't move when putting the drive lever into forward or reverse.
Mar 24, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Goes forward but moves slow
If its a hydrostatic transmission your pump is bad.
Jul 18, 2013 | Husqvarna Garden
No forward drive. hyd.ok, reverse ok.
check the linkage as the same pump and hydro motor drives both directions
Sep 01, 2012 | John Deere 300 / 316 Hydrostatic Tractors...
Linkage inside gear box does not engauge. Mechanics work to the bolt on top of the bottom gear (differential) box. Neither forward nor reverse work.
Most likely a hydrostatic transmission and most likely it is dead. Buy a new one or look around on google and craigslist for a used one. Maker and model number will be printed on top and possibly stamped on the bottom. New hydrostatic transmissions cost more than a new mower.
Mar 31, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lt1000 hydrostatic drive stuck - will not engauge or disengauge
Does the tractor try to move or **** in any direction, if so you may want to check to see if the disk that controls the brakes is stuck, I've seen this many times.
May 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Oct 10, 2009 | Garden
FORWARD AND REVERSE GEAR SELECTION BACKWARD
Recheck your belts, does your engine have a pto
Jul 28, 2009 | Garden
Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Oct 14, 2008 | Garden
Garden Logo
89 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
