Question about Cameras
Have jvc digital video camera get error code E03 the tape box will close with out a tape but not with one.
  • shirleykruck Oct 07, 2009
    l will look in to all the the facts you said.thank you
  • 10,515 Answers
E03 - Take up error.
Most common in the Mini-DV models. This problem can be defective reel tables, or it can also be a defective rotary encoder. You can expect to pay intermediate to major labor for this type of repair. Parts are nominal.
I am sorry to hear regarding regarding the Problem. You can try the below mentioned solutions. If that work, it's perfect unless you need to send the unit back to JVC for repair.
Cold Reset The reason it tells you to REMOVE AND REATTACH BATTERY is not that the battery is bad, but that removing all sources of energy (battery and power cord) causes a COLD RESET. When you use the unit's on/off switch, parts of the camera are still receiving power and so you do not get the benefits of a COLD RESET. Just like your car; turning the ignition off will still power the clock and radio. You have to completely remove all power. If you are lucky, the camera will reset itself and start working again. Solution #2: Awareness of Humidity It seems older units would issue the same SAFEGUARD MODE error message for more than one problem. For example, older units do not tell you that they are shutting down for an hour because they detected high condensation, or moisture. So you play with the camera, remove the battery, reattach it, remove the tape, reinsert it, stand on your head, pray to your god, go to the bathroom, and voila! The camera is working again. It was nothing you did, just that the humidity went down enough for the unit to start working again. So consider high humidity as a possible source of the problem. If it is a rainy day, or you are near the sea, you might never get it to work that day in that location. Solution #3: Head Cleaning If you have never used a head-cleaning tape on your camcorder, you might give that a try. Mine has come back to life a few times by doing just that. Just don't do it too many times in a row because you can permanently damage the head. Read the instructions. So we have covered a few reasons why these errors come and go as if by magic. They are intermittent and recurring. The camera will appear to work at times, and the next minute it shuts down. Solution #4 : Fake Solutions Another reason why the problems come and go is that, as several technicians have reported, the problem can be a loose connector inside. That is why some people report that tapping the camera gently or rocking it side to side has brought it back to life. Some have gone as far as putting cardboard between the tape door and the tape mechanism in order to exert pressure and keep the camera working. I can only warn you that these kinds of "repairs" are temporary and likely to damage the unit further. Control your anger! Solution #5: Compressed Air On some models, there is no shield covering the many delicate electronic and moving parts in the tape mechanism when you open it to replace the tape. A piece of dirt, grain of sand, or other debris can get caught in the tiny gears and stop movement or throw them off alignment. You can explore this possibility by getting a can of compressed air at any computer shop and blowing it into the inside of the camera. Follow the instructions, keeping the air nozzle however many inches away from the target as they say. Practice on some other object first, because if you tilt the can or hold it too close to the target you can freeze the target and do more damage than good. This applies to fingers too! Solution #6: Tape Age, Brand, and Type Have you tried using a brand new tape? Or only your really old ones? Try a new tape. Now for the controversial issue of what brand of tape to use. Controversial because JVC's own Stacy Sample, Service Coordinator for JVC in Houston, TX says that "TDK and Maxell tapes tend to be two brands that are very problematic in our digital line wherein Panasonic, JVC and Fuji seem fine. We just find that TDK has the most problems, Maxell is a close second and Sony is 50% of the time. The others I mention rarely have a problem." Why JVC does not make this information available when you purchase the unit or visit their many websites is beyond me. A different point of view I ran into is. Yes, there is an issue, but it has nothing to do with the brand, but with the tape type. There are MP and ME tapes. These two types use different particles, and different lubrication. The two lubricating materials form some sort of goo when mixed together, if you use both types of tape in the same unit. So as long as you don't mix tapes of different types, they will work just fine in your camcorder. Some refer to these types as "dry" and "wet", but I don't know which is which. In any case, it is not known (to me) how accurate this point of view of not mixing tape types is. Solution #7: Do not store tape in unit Because of the delicate nature of the miniDV mechanism, do not store the unit with a tape inside. The theory is that a loaded tape will put pressure on parts of the mechanism and increase the chance that parts will stick together, making the tape harder to be pulled by the motor, causing the SAFEGUARD error.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 07, 2009
E03 eject and reinsert tape
Because of the black rubber part you have that problem so now you need to find one and insert on the bottom part of you tape deck for your camera to work.
Feb 11, 2014 | JVC GR-D73E Mini DV Digital Camcorder
Error code E03,camcorder shuts down,won't eject tape.How do I fix it.
E03 means the motor drive has failed.The damage is permanent. The camcorder GR-AX5 is too old to repair.Recycle it and buy a new one.
Nov 10, 2009 | JVC GR-AX230 Camcorder
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the normal
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
Getting error "E03 unit in safeguard mode" on JVC GR-D200U video camera
to the mechanism.
Nov 24, 2008 | JVC GR-D370 Mini DV Digital Camcorder
E03
my jvc gr-DVX MINIDV PAL KEEPS GETTING ERROR CODE EO3 PLEASE HELP
Dec 04, 2007 | JVC GR-DVL20EG Mini DV Digital Camcorder
Error message: E03 Unit in Safeguard Mode - Remove and reattach battery
HI, ERROR CODE E03 MEANS THE THE TAPE IN YOUR CAMCORDER IS TOO SLACK, ALL YOU NEED TO DO IS EJECT THE TAPE & TIGHTEN IT USING YOUE THUMB LIKE I DID, ONCE I PUT THE TAPE BACK IN THE ERROR HAD GONE ( FOR EVER I HOPE!) GIVE IT A GO ANYWAY, HAYLEY X
Mar 19, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
Cameras Logo
23 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
