Question about Garden
Bolens 4.5 Briggs and Stratton: I prime the carb
Bolens 4.5 Briggs and Stratton: I prime the carb and it runs the gas out then dies, but if I keep priming it until it warms up it runs fine. Then I have to do it again when cold,
    Problem Solver:
  • 14 Answers
Be sure the fuel is fresh....meaning, fresh from the gas station. IF that doesn't fix it, replace the carb.
Posted on Oct 08, 2009
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Carb float bowl has an electric selanoid on it no wires going to it how does it work and where do wires hook up
Carb solenoid and a fix, dont forget the cut off valve ...
? 10:23
https://www.youtube.com/watch?v=gQw2pQ_oa6o
Jul 16, 2012 - Uploaded by Murray Mayhem
would you advise doing this on a 2004 Bolens with a 15.5 Briggs..... I have a 15 hp Craftsman-koher riding lawn mower that won't run. ... when I put power to it, and the there is gas in the bowlwhen I take it apart. ... Rename the video "How to Bypass Carb solenoid for Temp Fix on no start" Try to edit that ...
Small Engine Repair: How to Check a Solenoid Fuel Shut ...
? 4:40
https://www.youtube.com/watch?v=Kr6UayxyVwU
Jul 23, 2011 - Uploaded by smallengineshop
When the engine is stored with fuel in the carburetor for long periods, there is a .... There is gas in the carb in the lower portion where the float is. .... Engine hadn't been run for over a year and the solenoid would not operate. .... DIY - CarburetorReplacement On Lawn Tractor With Briggs & Stratton Engine ...
Dec 01, 2015 | Briggs & Stratton Garden
We have a briggs and stratton mower that has been in storage for 5 years with very few hours on it, it will start but dies shortly after.
needs to have carb cleaned out. most likely the main jet in the carb is plugged. symptoms include only running on choke and dies when choke is turned to run. or if you only have a primer bulb, it will only run for only a few seconds every time it is primed. if you are qualified to work on the carb, dont forget to start with fresh gas and possibly new fuel line and filter. R
Sep 03, 2012 | Poulan Pro 22inch 625 Series Briggs ...
Fires up good but dies out?
you have a plugged primary jet in the carb
Aug 04, 2012 | Briggs & Stratton 3000 PSI Pressure Washer
Lawnmower has been in storage for 6 months. Has new good gas, and gas is flowing to carb. However, engine will not start without priming carb with gas, then runs until primed gas is exhausted. ...
this is from a post i just did for anothe engine but i think it applies to you also.
get a product called START. this stuff is amazing it has solved all my engine problems including a couple like yours. any wal mart should have it. add to your gas and the longer it runs the better it runs. i am telling you it is worth the 6 bucks. i had a 4wheeler that never ran right, always had to half choke it. even though i cleaned the carb twice. added this stuff and by the time that tank was gone it was running like new. if that doesnt take care of your problem then it needs to go to the shop Now your situation i know is dirt or varnish in the carb i have had this problem also. and start worked for me on that also. mix it in the gas and keep it running even if you have to keep priming it
Nov 12, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a craftsman briggs and stratton 550 series silver edition lawn mower and when i turn my lawn mower on the engine revs and then lets of over and over again like it is about to die but dont... what...
i have a brand new craftsman briggs &stratton silver engine series 5.50 158cc it will start but will not run unless i keep pushing the prime button to give it gas once i stop so does the engine
Oct 22, 2010 | Garden
I can start my 4.75 HP Briggs & Stratton Lawnmower but it dies after a few minutes. I replaced the armature but the same thing happens. I can keep it running if I press the prime bulb a couple of times...
Try replacing the float and needle. The float (floats) and pulls the needle up to let gas through to the carb. It will stay running as long as you press the prime bulb because this sends gas straight to the carb without going through the gas bowl. It's best to remove the carb and clean it then replace the float and needle
Sep 05, 2010 | Craftsman Garden
Briggs & stratton 550 / surges, gas hog
check your air filter. If it's clogged, the engine will spool up to keep from dying, run for about 15 seconds, then it will happen again. If that's it, just clean the air filter. Solved my problem
Jul 26, 2010 | Briggs & Stratton Garden
21hp b ANd S engine keeps stalling unless choked
CARB CLEANER FOR CARS WILL WORK JUST FINE,BUT YOU MIGHT HAVE TRASH IN THE BOWL.IF SO YOU WILL HAVE TO TKE THE CARB APART
Aug 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
760 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
