Question about Sony Playstation 3 (PS3) Console
My ps3 wont go back to hdmi from av.i did the display thing but no luck.
  • 3 Answers
Check this solution I hope it works for you
http://www.portfolioofpb.com/blog/ps3-blank-screen-switch-inputs-hdmi-to-composite-to-hdmi
Posted on Dec 11, 2009
I used a xbox hdmi cord for my ps3 and changed my ps3 settings to be compatible. The I tried to use the av audio cord and it did not show the picture. How do I fix this?
You need to do a video reset to your system. You might have to do this every time you go between HDMI and A/V. Here is a link how. It's really easy. ^^ Good luck. P.S. It's the same for every model of the PS3.
How to RESET PS3 display output settings from HDMI HD to SD AV Cure blank...
Apr 19, 2015 | Sony Playstation 3 (PS3) Console
Hi our PS3 has no sound or picture. It does have the green power light on.
What is probably happening, is your PS3 is set for the wrong type of output. If you are using an HDMI cord, try switching to the AV cables that came with your PS3, and set your TV at the appropriate input to correspond with the AV hookups, and see if the picture works then.
If you are using the AV cables, it may have been set to HDMI accidentally. You need to use an HDMI cord, and hook the PS3 up to an HDMI compatible TV or monitor, and select the HDMI input. Once you get the picture working, go to Settings>Display Settings and set the display you wish to use.
May 16, 2011 | Sony Playstation 3 (PS3) Console
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    My playstaion 3 wont funell any picture through the av scart lead or the hdmi lead but it still turns on and is running fine ?
    Please try the following steps :
    Connect your PS3 up as normal, A/V or HDMI, it does not matter.
    Turn the PS3 off into standby mode (red light on)
    Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Release the power button after you hear the second beep.
    Wait for the PS3 display to be reset.
    You can use this method when you change from A/V or HDMI, it simply resets the display back to standard definition
    Hope this helps
    Oct 28, 2010 | Sony Playstation 3 (PS3) Console
    My first generation ps3 (20g) will not display image on tv while trying it with hdmi and av cables. I;ve tried holding down the power button for the 10 sec and all that, but It wont display image, although...
    Have you tried it on a different TV, you need to narrow down weather it is the PS3 or the TV. If it doesn't work on another TV the PS3 GFX card will be faulty.
    If you normally use HDMI try and use a different cable or try it on a friends (borrow one) just to prove yours is good.
    Let meknowhow you get on. Not sure you can replace the RSX GFX in the gen 1.
    Good Luck
    Oct 17, 2010 | Sony Playstation 3 (PS3) Console
    My ps3 was switced to hd and wont switch back to a av cable
    You have to set it back to the regular cables the same way you did with the HDMI
    Feb 15, 2010 | Sony Playstation 3 (PS3) Console
    Ps3 not conecting on 2 samsung tvs
    Your ps3 could be in component mode. You will have to hook it back up on component mode, and go to the ps3 menu and change the setting to hdmi.
    Aug 11, 2009 | JVC LT-37X776 37 in. LCD HDTV
    No picture or sound
    Your display needs to be reset, Turn the ps3 off. Then turn the ps3 back on but continue to press the power button until you hear the beeps then it should work fine :)
    Aug 05, 2009 | Sony Playstation 3 (PS3) Console
    No signal on my TV
    try connecting the ps3 to the HDMI only, now when the ps3 is off and all but the single red light is on rest your finger on the on button for about 8 seconds, as soon as you touch it it will turn on but just wait a bit and you'll here the a second beep- this should reset your ps3's video output settings. Try it out, it works for me when i go back and forth from av to HDMI.
    Please remember to rate my response if helpful.
    May 30, 2009 | Sony Playstation 3 (PS3) Console
    AV multi out
    when the power is off press and hold the power button until you hear two beeps
    May 14, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    293 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
