Question about Eureka Vacuums
I think there is a part missing off bottom where wheels are above main roller if flipped over where can i see a manual to check
  • 21 Answers
Hi-
check this website for your Eureka Vacuum:
http://www.eureka.com/owners_guide.jsp
cheers
Posted on Oct 07, 2009
Dyson dc50 the roller head stops spinning after
Hi, it's Jim from Crucial Vacuum!
One of the main reasons most brush rollers begin to get jammed and eventually not turn would be due to a clog. Turn off the vacuum and flip it on its side. Is there any noticeable debris,such as hair or large carpet fibers? If you're looking to clean out your brush roll do the following. For the DC50 there should be a red button below the vacuum and just above the brush roll. Push this red button, this will allow the brush roller to be removed. On the brush roller itself you'll notice two more similar looking red switches. Flip these up allowing you to remove the top of the roller and gain access for cleaning. Clear out any debris and try rotating the brush roll once around to see what else may fall loose. Take note of how the bristles look too. Are they worn down and loose? If so it may be time to change your roller.
This handy video may further help in troubleshooting your Dyson.
https://www.youtube.com/watch?v=HpWk5trjvO4
Another item to check would be your vacuums belt. If this is loose as well it can affect your vacuums brush roll. Both are simple and easy fixes and can be done in just a few minutes.
Should you need any replacement parts for your Dyson in the future please feel free to order direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Check out our lineup of Dyson replacement parts at the below link.
http://www.crucialvacuum.com/dyson-vacuum-parts.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Oct 18, 2014 | Vacuums
Brush roll won't turn on for the shark NV22L vacuum. the light on the brush roll is dark, not red or green
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
Feb 10, 2011 | Shark Helmet NV22L Shark Navigator Upright...
When i removed the bottom panel to clean out the roller brush, the front wheels fell off. I can't figure out how to put them back on!
I( think Dirt devil wheels are held on by a little clip, kind of round ish. Check the other wheel and see if it has that kind of set up. Chris
Feb 09, 2011 | Dirt Devil Featherlight Bagless Upright...
HOW DO YOU CHECK OR CHANGE THE BELT?
remove 4 Phillip screws from the bottom one near each corner pry up the bottom panel then just pull the brush roller up . put the belt over the roller push the roller back in place and flip the belt over on the shaft replace cover & screws.
Dec 23, 2010 | Euro-Pro NV31 Infinity Vacuum
I have a senteria about 4 yrs old. it bounbes
Check the wheels and axles for damage or bent shafts. Remove the bottom cover and inspect the brush roller for damage--breakage of the roller, bad or broken end bearings, missing brush sections, or something stuck to the roller like a wad of gum or something. Hope this helps!
Dec 26, 2009 | Kirby G4 Bagged Upright Vacuum
How to clean turbo brush of harmony electrolux and put it back together properly
Wait, there are two more screws that must be removed before the top shell will come off. They are located under the wheels. Pop the wheels out by simply inserting yoru finger or a small tool into the wheel and pulling straight up. Remove those two screws and then you can proceed as mentioned above.
When reassembling the head, if the shell does not snap back onto the base, check for plastic chips or other debris in the narrow slots on the underside of the shell. Clear these slots out and the head should easily snap back together.
Dec 02, 2009 | Electrolux Harmony Canister Vacuum -...
My roller isn't spinning. I think the band is not on correctly.
With the vacuum unplugged, flip it over and pull on the belt that runs the roller...if it is loose or comes all the way out...it is broke or has fallen off. Use your instruction manual to replace or install the belt. If you don't have a manual ...click below to look at a video that will help.
http://www.kirby.com/Portals/0/videos.html
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE MY HELP
Nov 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Burning smell
I had burning smell and some visible smoke which I tracked down to the handle area. The mains socket at the bottom of the handle had burned out. When I pulled the plug out I noticed that the prongs were blackened and scorched. I will replace the socket.
Nov 02, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Self propel not working, burning smell
Flip the vacuum cleaner over and check the roller brush. Is it full of string and hair? If so, unscrew the four phillips-head screws holding the plate on that covers the roller brush; pull out the brush, and cut off/clean off all the hair and string. Replace everything and try running the vacuum. Alternate solution: perhaps the belt that makes the brush go around is broken. If so, follow the above steps to remove the roller brush, then replace the belt.
Oct 11, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
Hoover Encore Supreme belt replacement
Remove the bottom plate that covers the brush roll and remove the roller. The plate is removed by releasing two clips at the back corners of the plate on either side. Take the roller and install the belt around the pulley and put the other end of the belt through the access hole in the vacuum body. Replace the roller and turn it by haand to ensure that the belt is not pinched. Replace the bottom plate and turn the roller again (same reason).
If you look at the area beside the rear wheel between the hood and the main body, you will see a clip incorporated into the hood. Take a screwdriver and pry it away from the main body. Do this on both sides. You will find a similar clip at the hood just beside the back corner of the plate in the front where the plate clips are located. Pry these as well and hood will come loose. Now you can turn the machine back on its' wheels and remove the hood. You will see the belt where it comes through the main body and you can grab it with a couple of fingers and stretch it onto the motor shaft. Replace the hood and the job is done.
Mar 21, 2008 | Vacuums
Vacuums Logo
50 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
