Question about Silver Cross Balmoral Pram Carriage Stroller
Assembly of wheels ie washers - Silver Cross Balmoral Pram Carriage Stroller
    Problem Solver:
  • 13 Answers
I have an instruction manual for your stroller if you want to write me at payitforwardx2 @ gmail . com
Posted on Apr 23, 2010
WHAT DOES IE STAND FOR?
LE = MOTOR IS BLOCKED
Faulty open circuit wiring to stator assembly.
Sep 20, 2014 | LG WM2688HWM TROMM SteamWasher
Sewing machine wheel won't turn, motor whirrs
So it sounds like the motor is working but nothing happens? And the hand wheel works ok by hand but nothing when the motor is engaged.
You've broken a belt. I'm not familiar with the 930, but if it has an internal motor... take it in to have it done. It's way too easy to knock these out of time. Spend the extra cash and have it cleaned lubed and adjusted too.
Sep 06, 2012 | Bernina Sewing Machines
How do I remove wheel? from pressure washer?
You first have to pry the cap off the wheel with a screwdriver then under the cap there should be either a pin which you pry off or a nut which you loosen.
Mar 19, 2011 | Simpson Garden
Don,t take the water out
This is a really common problem that most people send hundreds when they can fix it themselves. Power off your washer, put it on its side. Your going to see four to six silver bolts with hex heads located in the center holding in a plastic device known as the filter assembly. Remove the screws and find any hair inside the assembly. Remove the hair and put the screws back in. Even the smallest amount of hair inside the filter/drain assembly will cause this problem. ie WASHER EXPERT
Jan 21, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Servicing front hubs
Automatic Locking Hub
  1. Shift transfer lever to the ``2H'' position, then move vehicle forward and rearward approximately three feet.
  2. Raise and support vehicle, then remove wheel and tire assemblies.
  3. Disconnect brake hose from caliper.
  4. Remove caliper locking bolt.
  5. Rotate pad assembly upward then remove pad retaining clip and caliper assembly
  6. Remove brake pad support bracket.
  7. Remove hub cap retaining bolts, then the hub cap, Fig. 15.
  8. Remove housing assembly, snap ring and shims.
  9. Remove drive clutch assembly, inner cam and lock washer.
  10. Using tool J-36827 or equivalent, remove hub nut.
  11. Remove hub and disc assembly.Manual Locking Hub
    1. Shift transfer lever to the ``2H'' position and set free wheeling hub into Free position.
    7. Remove housing assembly retaining bolts then the housing assembly Fig. 16.
    8. Remove snap ring and shims.
    9. Remove body assembly and lock washer.
Jul 02, 2010 | 1991 Isuzu Trooper
Rotator arm is detached from gear
I am assuming the plastic wheel type device which moves the washer arm has come out.
I think you will have to buy the whole rotor assembly. Should cost around $50.
Go to page 17 of Parts Manual and check part no. 5 Rotor assembly.
I have seen it is available from Fisher and Paykel parts shop online. They are located in Milwaukee (ie, if you are in USA)>
Jun 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How long does it take to fix front bearings on a 97 dodge caravan? and cost
About an hour a side...This is the whole job and pictures....
The hub and wheel bearing unit is serviced as a complete assembly. Replacement of the front drive hub and bearing assembly can be done without having to remove the steering knuckle from the vehicle. However, if the hub/bearing assembly is frozen to the steering knuckle, removal of the steering knuckle is required.
  1. Disconnect the negative battery cable.
  2. Remove the cotter pin from the end of the stub axle. Remove the nut lock and spring washer. With the brakes applied, loosen, but do NOT remove the axle nut and washer with the vehicle still on the ground or damage to the wheel bearing will result.
  3. Raise and safely support the vehicle. Remove the wheel.
  4. Remove the front brake caliper assembly from the steering knuckle assembly and support from the strut assembly using a strong piece of wire.
    1. Remove the front brake rotor from the hub/bearing assembly.
    2. Remove the retaining nut and washer from the halfshaft stub axle.
    3. Remove the ABS wheel speed sensor from the steering knuckle.
    4. Remove the 4 hub and bearing assembly mounting bolts from behind the steering knuckle.
    5. Remove the hub and bearing assembly from the steering knuckle.
  5. To install:
    1. Thoroughly clean the mating surfaces of the steering knuckle and the hub and bearing assembly of any foreign material or nicks so the surfaces are clean and smooth.
    2. Install the new hub and bearing assembly and tighten the mounting bolts in a crisscross pattern to 45 ft. lbs. (65 Nm). Be sure the hub and bearing assembly is seated squarely against the front steering knuckle.
    3. Install the disc brake rotor.
    4. Install the brake caliper assembly onto the steering knuckle.
    5. Install the axle washer and nut. Tighten but do not torque.
    6. Install the ABS wheel speed sensor.
    7. Install the wheel and lug nuts. Torque the lug nuts, in sequence, to 95 ft. lbs. (129 Nm).
    8. Lower the vehicle. Do NOT roll the vehicle until the axle nut has been properly torqued or damage to the front wheel bearings will result.
    9. With the vehicle's brakes applied, torque the axle nut to 180 ft. lbs. (244 Nm). Install the spring washer, nut lock and a new cotter pin. Wrap the cotter pin prongs tightly around the axle nut lock.
    10. Reconnect the negative battery cable. Check the wheel alignment.
The hub/bearing assembly is attached to the steering knuckle with four bolts
Removing a hub/bearing assembly
If the hub/bearing is "frozen" to the steering knuckle, separate the ball joint and lightly tap on the hub/bearing from behind
The hub/bearing assembly should free itself from the steering knuckle
About $60 a hub.
May 23, 2010 | 1997 Dodge Caravan
How does front wheel assembly look? Order of
I figured ut how the front wheel parts went together and then the brakes by lookng at the picture of the assembled bike..
Dec 15, 2009 | Mongoose Toys
R&R Steering Wheel Assembly and/or Steering Column Assembly
if you disconnect the battery and let it sit awhile this will disable the airbag.
May 15, 2009 | 1998 Ford Explorer
Silver Cross Balmoral Pram Carriage Stroller Logo
79 people viewed this question
Top Silver Cross Baby Gear Experts
ray gallant
Tom Chichester
Are you a Silver Cross Baby Gear Expert? Answer questions, earn points and help others
