Question about Gateway MX6454 Notebook PC
Charging problem My laptop just stop charging at 23% 1hr ago battery works power cord as well. I have no clue whats going on nothing has been changed add or removed from this laptop in 3 months I only play wow on it. HP DV9730 vista
    President:
  • 2,600 Answers
Welcome to the world of the DV9000s....if it isn;t a motherboard issue, it is a power issue. Do not trust either the power cord or the battery or the computer for that matter because I have seen over and over that all three components are not playing well with each other in these systems and the DV6000s. It could be very possible that the battery has bad or damaged cells in it and will probably run fine for a while and then crash suddenly. That is because it is using the good cells and then a bad cell kicks in and....nothing.
Take the battery out and just hook up the charger, if it runs fine for a couple of hours just on the charger then I suspect there is no problem there, chargers tend to overheat, then their voltage reulators will start to fail and then the battery is discharged or over charged and then everything fails.
Posted on Oct 07, 2009
How do i fix my lenovo tablet if it wont take charge?
There are two troubleshooting tips for this:
  • try changing the battery. Sometimes the battery can be bad, not keeping a charge long enough to allow the computer to power on.
  • Try a new power cord. First thing is, there can be a short that intermittently causes the computer to show as charging, but it stops actually charging after letting go of the plug. Second, the cord is going bad and not allowing a full charge to go through.
Jun 29, 2014 | Lenovo ThinkPad Computers & Internet
Samsung 145
Dear frnd,
Probably its battery problem but before change the battery you have confirm first its battery or Adopter problem. you need do first check the adopter to another laptop which has same charging pin . if its doesn't work with another laptop then you change the adopter but if the charger works with other laptop then you need to change your battery. try it..
Jan 15, 2014 | Samsung N145-JP01US Netbook
My acer aspire 8930 suddenly stopped charging the battery. We put it in my husband's identical laptop and it charged fine. I researched on net and using info found, turned laptop on with battery r
Just because all systems look go. Does not mean the power cord is working correctly and the charging portion of the power supply unit may not be working you will still be able to power the computer on but not charge replace that unit and you should be back up and charging again. You know it is not a battery problem it is the cord and component due to your test. Makes sense to me also one other factor to consider, the battery may be charging but will not hold the charge be sure to fully charge the battery and see how long it takes to drain down. Just a suggestion. John
Apr 14, 2012 | Acer Computers & Internet
Laptop will not charge. Brought new battery and and it did charge for a while now it will not charge at all. Changed power cords and still nothing. Need all programs for classes. It's urgent that...
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Aug 21, 2010 | Compaq Computers & Internet
Hello, I am having problems with my Compaq nx6110 laptop not charging. It is not the battery, as I replaced it at the end of December. The problem seems to be that the charge isn't reaching the battery,...
If you remove the battery, does the AC Adapter power the computer? Does the laptop have a barrel type power connector? I have replaced several power connectors for broken center pin. Does wiggling the power connector affect the charging light?
Mar 20, 2010 | HP Compaq nx6110 Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Help! Compaq Laptop "Plugged in,Battery Not Charging"
I had the same problem on my CQ60. HP battery test showed one or more cells not working. After spending about 2 hours talking to some guy in India,or somewhere, he came to the conclusion that my battery was bad. HP sent me a new battery, which fixed the problem.
kenbun
Sep 11, 2009 | Compaq Presario CQ60-220US PC Laptop
Gateway MX6454 Notebook PC Logo
119 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
