Question about InFocus Office Equipment & Supplies
The projector colors are different than whats on the computer. We have tried adjusting everything and it doesn't help.
  • 2,237 Answers
You need to post more info for better assistance, such as model of projector.
Posted on Oct 16, 2009
Picture shows 3 colors on everything.example.if there's a hand.there's 3 hands and each is a different color Blue .red.green
There are actually 3 projectors inside, each handling one of those three colors which, together, make all the other colors. This is called "out of register" where they are aiming slightly differently. These need to be adjusted.
Jul 31, 2014 | Televison & Video
Color red not coming through
Have you tried using a different input on the projector? that could help narrow down between a hardware issue or settings. Double Check all color settings and reset them to defaults if you are not sure. Otherwise, it's likely an issue with the input board and it needs to be replaced.
Oct 09, 2013 | Sanyo PLC-XU101 Projector
The color on our cp-s240 projector is really bad. When I go to menu, color and tint are greyed out so I cannot adjust them, what should I do?
Often you will see that you have lots of options in your menu that appear grayed out. This occurs when you do not have an input device connected to your projector.
In order to have access to all the menu options, simply connect an input device (TV,DVD player, computer, etc) to your data projector and start the projector.
Assuming everything works properly, if the projector starts receiving a signal, you will have all your menu options available.
I'd also note that image discoloration can also be caused from defective/damaged cabling, cables not being connected fully, bent pins depending on the type of cables you are using, and also for internal problems. If you can not adjust your settings to achieve satisfactory color, check your cables for damage and make sure they are all connected properly.
Jan 05, 2011 | Hitachi CP-S240 Multimedia Projector
Everything is yellow! It was working fine a week ago but when I went to do a presentation yestereday everything is yellow??? I tried adjusting the colors and I tried a second computer but yellow
hello,
what this indicate from the color display on the system mean that the display sensor (lens)in getting weak it need servicing or a replacement, to to this servicing you will have to unscrew (open) from the stroll then clean up the lens with little spirit solution on the surface with care allow the solution to dry up it self then reset the programming on it please while doing this you will have to be very careful with the wire connection around ,but if this fail then you will have to get a replacement on it
This are recommended fix is to replace the lens. You can generally find replacement parts at these websites:
www.projector.com
letsgodigital.org
comforu.com
technabob.com
techshout.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing a lens is not a difficult repair and can be accomplished by the average do-it-your self offer. If you decide to order the part and wish to repair this on your own
thank you and thanks for you sing fixya.
Jul 01, 2010 | InFocus X3 DLP Projector
I have an Epson EMP-S4 projector. When I hook it up to my laptop the light comes on, but everything is in a shade of pink. I've tried adjusting color to no avail. Tried with another computer, same...
Check your cable you are missing a primary color and it could be that your cable is missing a pin/bent ck on both ends and even the projector input.
Jun 15, 2010 | Office Equipment & Supplies
LCD projector not displaying color only black and white
Did you ever see color on this projector?
It could be the composite input cant detect the "color burst" 3.58 mhz signal for chroma.
Have you tried a different input?
That could help you track down what the problem may be.
Oct 31, 2009 | Televison & Video
Epson LCD Projector Model: EMP-S1H
Hi there. What windows are you using? There are a few different ways of chaning it but usually diferent depending on what make computer and what windows you are running, but normally on xp you can go into display and go to the advanced settings, then click on graphics setting and it gives you the option to change everything including temp, saturation etc.
Feb 01, 2008 | Office Equipment & Supplies
Green tint
Adjust the color temp, it worked for me. I had to turn mine off but now the color is perfect.
Jan 24, 2008 | Dell 3200MP Multimedia Projector
Colors displayed
Go to Menu, Advanced, and set the color adjustments to RGB. That should work.
Dec 03, 2007 | Eiki LC NB2UW Multimedia Projector
LCD Toshiba TLP s10
You probably have the input set to component video (Y/Pb/Pr) which will distort the colors
Oct 23, 2007 | Hitachi CP-X270 Multimedia Projector
93 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
