Hotpoint washing machine
Hi !
my washing machine is maching too much noise during spin .
could you please helpt me sort it out
  • moogie Feb 08, 2008
    when the drum rotates it clicks sounds like a bra wire or is it bearings going how do i check for bra wire
  • 139 Answers
Hello im sorry to say that you machine is in serious condition and with out a bearing transplant the prognosis is fatal.
The Problems what it could be
1 drum bearing. should not be tackled by the non technical types because you do need to know what your doing.. depending on what model it is i can give you some instructions.
2. Broken spider on internal drum, (the one that spins) can be done but better tackled by an engineer
3. Something caught in the drum most common one is bra wire.
To check to see if it is the drum bearing then open the door and hold the drum (steel bit lol) at the 12 oclock and 6 o clock and se if there is any movement if so its either problem 1 or 2
if you need any help dont be shy to ask
im here free of charge...
Posted on Dec 25, 2007
Hotpoint washing maching making a loud noise on spin how to get in to it
see this possibles causes:
During fill only
air gap device, crack see the diagram+tube can be crack+inlet spout break.
During drain and spin only
check the hose, allternative the outer tub
All the time: main tub +pump+outer tub defective replace
see the diagram
Jun 18, 2012 | Bosch Washing Machines
Hi. i have had funny noises during last couple of washes. now washer wont drain programs are responding fine but washer keeps filling up and not draining.water backed up and came out of the drawer hotpoint...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Noisy when spinning
bearing gone cheaper to buy a new one
Jan 23, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Very noisy and moving around Hotpoint washing machine
there are four shipping bolts in the back of the washer that need to be removed they are long bolts connected to plastic pieces. unscrew them and remove the plastic pieces
Oct 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint First Edition washing maching won't spin
hello any spin problems could be down to the module circuit board
shaun
Aug 02, 2009 | Washing Machines
Hotpoint VBSR2080WOWW washing machine vibrates with loud noise
hi,
this is a generic problem with top-loading washing machines. when the distribution of load is not uniform, it gives sound when spinning. if it produces noise even after equal distribution of clothes, the problem lies in the suspension. this is not a major fault, and can be put up with, rather than spending dollars on fixing it. this will in no way cause any special wear and tear for the machine.
cheers
Jul 22, 2009 | Hotpoint VBSR3100D Top Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Washing machine
Certainly you could find some screws to unscrew to view the tub. Is this a front loading one?Check the shock absorbers or springs & see they are in place. You hv to open it up or more damage will occur. Plug off the wall please.
Mar 16, 2007 | GE Profile Prodigy WPSE4200A
Washing machine noise
my washing maching will not spin out all the water in the spin cycle.
Dec 20, 2006 | Hotpoint VLXR1020A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
