Question about Kenmore 700 sq. in. Cooking Area Gas Grill 14116325
The regulator is freezing up. I just replaced the tubing, regulator, and hose with new oarts. Still freezing up
  • 388 Answers
Are you opening your propane tank valve all the way? This will cause what you are seeing and there is an easy fix - when you open your propane bottle valve, only open it one to two turns and your regulator shouldn't freeze up.
Posted on Oct 07, 2009
  • bulldogchief
    bulldogchief Oct 08, 2009
    Thank you for your rating of two thumbs up (not helpful)...it really makes my day when I try to answer what is arguably a vague question (NO Model Number, NO Make) with the simplest answer possible. You don't provide the necessary information and then you give me 2 thumbs when there is no way on earth anybody could answer your question any better with what little information you provided...thanks alot bud.
1995 isuzu pickup wont start sometimes
Fuel Pressure Regulator is located on the fuel rail.
1. Disconnect the negative battery cable.
2. Properly relieve the fuel system pressure.
3. Remove the air cleaner outlet tube(s).
4. Remove any necessary components to access the pressure regulator.
5. Disconnect the vacuum hose from the pressure regulator.
6. Remove the pressure regulator attaching screws.
7. Remove the pressure regulator from the fuel rail.
To Install
8. Discard the O-rings on the pressure regulator and replace them with new ones.
9. Lubricate the O-rings with clean engine oil.
10. Install the regulator into the fuel rail and tighten the retaining screws.
11. Connect the vacuum hose to the regulator.
12. Install any components removed to access the regulator.
13. Install the air cleaner outlet tube(s).
14. Connect the negative battery cable.
Jul 03, 2012 | Isuzu Pickup Cars & Trucks
Where are all the freeze plug located on 4.6 w/auto. is there one between the block & transmission
Yes, there are expansion plugs (freeze plugs) on both sides of the engine block and at the rear of the engine block between the engine and transmission. There are also a couple in the ends of the cylinder heads.
With all that said, I would like to add that many times with that engine, the heater tube and connecting hoses can leak and be mistaken for a rear expansion plug leaking. I would definately check this before pulling the transmission out.
There is a tube that runs from the back of the water pump under the intake manifold and out the rear of the engine where it hooks up to the heater hose/heater core. This tube has a small hose connecting it to the back of the water pump. There is also a hole in the back of the engine block that will allow antifreeze from under the intake manifold to leak into the transmission bell housing area. When this tube or hose leaks, it often gets mistaken for a leaking rear expansion plug.
It is very easy to check for this. Remove the serpentine belt and remove the alternator and look under the intake manifold down in the "valley" between the cylinder heads. If there is antifreeze in there, the hose or the tube is leaking. Look at the picture below. Item #3 is the tube and hose assembly I am talking about. Usually, just the hose is leaking. It should be replaced with a short piece of SILICONE heater hose. On some of the vehicles, there are 2 hose clamps. On others, the end of the hose that is attached to the tube has a crimped collar on it. If yours is like this, you can fix it by carefully cutting the crimp collar off and replacing the hose using band clamps. (screw-type)
Also look for antifreeze leaking into this area from the front intake manifold runner. They tend to leak on the front runner near where the thermostat housing is located. These will also leak into the valley area and run out the back of the engine. If the manifold is leaking, chances are it is warped. DORMAN makes a replacement intake manifold kit just for this purpose because it has been so common. It is also very easy to check for this with the alternator removed.
The DORMAN part number for your vehicle is 615-178 (See second picture below)
Sep 21, 2011 | 1996 Ford Mustang
How to replace fuel pressure regulating valve
1991-94 Models - REMOVAL & INSTALLATION
  1. Remove the air intake tube and resonator assembly.
  3. Remove the bolts from the fuel line clip.
  4. Using a 15 / 16 in. (24mm) backup wrench to prevent damage to the inlet port and bracket, disconnect the fuel inlet and return lines from the pressure regulator/fuel rail assembly.
If difficulty is encountered accessing the fuel return line nut, loosen and/or remove the fuel supply and rail attachment fasteners.
  1. Disengage the fuel pressure regulator vacuum hose.
Fig. 6: Disengage the fuel pressure regulator vacuum hose
Fig. 7: Use a suitable wrench to loosen ...
  1. Remove the regulator assembly attaching screw, then remove the regulator assembly. Plug the regulator port in the fuel rail with a clean rag to prevent system contamination.
Fig. 8: ... and remove the mounting screw from the pressure regulator/fuel rail assembly
Fig. 9: Remove the fuel pressure regulator assembly from the fuel rail
  1. Do not remove the O-ring from the retainer in the pressure regulator fuel outlet, unless it is damaged and requires replacing. Always remove and discard the O-ring from the fuel inlet.
To install:
  1. Lubricate the new fuel inlet O-ring and, if necessary, the new outlet O-ring with clean engine oil, then install the O-ring(s) in the pressure regulator assembly.
  2. Position the regulator assembly to the fuel rail. Coat the threads of the attaching bolt with Loctite® 242 or an equivalent threadlock, then install the bolt and tighten to 106 inch lbs. (12 Nm).
  3. Connect the fuel pressure regulator vacuum hose.
  4. Connect the fuel inlet and return lines, then tighten the lines to 133 inch lbs. (15 Nm) using a backup wrench to prevent port damage.
  5. Cycle the ignition switch to prime the fuel system, then start the engine and check for fuel leaks.
  6. Turn the ignition OFF and install the air intake tube and resonator assembly.
Hope this helps (remember to rate and comment this answer).
Apr 29, 2011 | 1993 Saturn SL2
Truck stalls out in the mornings. auto zone said to hook aPSI tester to the fuel rale and they said it was to low i replaced the fuel pump still the same thing.auto zone .what a joke to the tune of...
Pressure regulator could be a factor, but may be part of the fuel pump assembly. Fuel filter could be a factor, but again, with some Chrysler vehicles the filter, regulator and such are all part of the fuel pump assembly.
Oct 03, 2010 | 2000 Dodge Durango
Where is the fuel filter located on a 1994 dodge ram
Fuel Filter REMOVAL & INSTALLATION CAUTION
Never smoke when working around gasoline! Avoid all sources of sparks or ignition. Gasoline vapors are EXTREMELY volatile! All 1989–93 Gasoline Engines and 1994–96 2.5L Engines The fuel filter is located in the fuel line on the inside of the left frame rail, just ahead of the crossmember. Fig. 1: Fuel filter location for gasoline engines 88471011.gif
  1. Relieve the fuel system pressure as described in Section 5.
  2. Unfasten the filter retaining screw and remove the filter from the frame rail.
  3. Wrap a shop towel around the hose connections to catch fuel spillage. Loosen the fuel hose clamps and disconnect the hoses from the filter.
  4. Remove the old fuel filter and replace it with a new one.
  5. Connect the fuel hoses and tighten the hose clamps. Position the filter on the frame rail and tighten the retaining screw to 75 inch lbs. (8 Nm).
1994–96 Gasoline Engines — Except 2.5L The fuel filter is integrated into the fuel pressure regulator which is mounted in the fuel tank. This unit is not controlled by the PCM or engine vacuum. It is calibrated to deliver approximately 35–45 psi (241–310 kPa) of fuel pressure to the injectors. If the pressure exceeds the maximum of the specified range, an internal diaphragm closes to route fuel back into the fuel tank. This system eliminates the need for conventional return lines from the engine bay and accounts for the name of the "Returnless'' fuel injection system employed in these vehicles. NOTE: Fuel tank removal is required for this procedure. Also needed will be external snapring pliers and proper hose clamp pliers, such as No. C-4124 pliers (available through Plymouth/Dodge dealers), or equivalent.
  1. Relieve the fuel system pressure as described in Section 5. Fig. 2: With the fuel tank removed, twist and pull the fuel filter/regulator for removal from the rubber mounting grommet 88471707.gif
  2. Drain the fuel tank and remove the tank.
  3. Remove the fuel filter/regulator (which is pressed into a rubber grommet) by twisting and pulling it straight up. Fig. 3: Use snapring pliers to remove the retainer securing the cover tube to the base of the filter/regulator 88471708.gif
  4. Remove the snapring retaining the cover tube, then slide it down to reveal the clear plastic fuel tube and its retaining clamp. Fig. 4: Cut off the old tube clamp without damaging the plastic fuel tube 88471709.gif
  5. Gently cut off the old clamp without damaging the tube, then discard the clamp.
  6. Carefully pull the tube off, then remove the filter/regulator from the fuel pump module. To install:
  7. Install a new clamp over the plastic fuel tube and attach it loosely to the filter/regulator. Rotate the unit in the line until it is pointed to the driver's side of the vehicle.
  8. Tighten the clamp using hose clamp pliers such as No. C-4124 (available through the Plymouth/Dodge dealer). NOTE: Do not use conventional side cutters to tighten the clamp.
  9. Slide the cover tube up to the bottom of the filter/regulator and install the snapring.
  10. Carefully press the assembly back into the rubber grommet by hand. It should be pointed to the driver's side of the vehicle.
  11. Install the fuel tank.
Jul 14, 2010 | 1994 Dodge Ram
What is the fuel pressure for a 1996 mercury sable?
Fig. 1: Fuel pressure regulator exploded view
CAUTION Observe all applicable safety precautions when working around fuel. Whenever servicing the fuel system, always work in a well ventilated area. Do not allow fuel spray or vapors to come in contact with a spark or open flame. Keep a dry chemical fire extinguisher near the work area. Always keep fuel in a container specifically designed for fuel storage; also, always properly seal fuel containers to avoid the possibility of fire or explosion.
  1. Remove the pressure regulator attaching screws.
  1. Remove the pressure regulator from the fuel rail.
To install:
  1. Discard the O-rings on the pressure regulator and replace them with new ones.
  1. Lubricate the O-rings with clean engine oil.
  1. Install the regulator into the fuel rail and tighten the retaining screws.
  2. Connect the vacuum hose to the regulator.
  3. Install any components removed to access the regulator.
  4. Install the air cleaner outlet tube(s).
  5. Connect the negative battery cable.
Hope help with this (remember rated this).
May 28, 2010 | 2000 Mercury Sable
How to change fuel filter on 2000 dodge durango
Here ya go! Please don't forget to rate!
NOTE: A combination fuel filter and fuel pressure regulator is used on all engines. It is located on the top of the fuel pump module.
To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain and remove fuel tank.
  3. Clean area around filter/regulator to prevent contaminants from entering pump module.
  4. Remove or disconnect the following:
    • Fuel filter/regulator by twisting and pulling up CAUTION
      Do not pull filter/regulator more than three inches from fuel pump module.
    • Old fuel tube clamp by gently cutting clamp, taking care not to damage fuel tube
    • Plastic fuel tube from filter/regulator by gently pulling downward
    • Filter/regulator from fuel pump module
To Install:
  1. Install or connect the following:
    • New clamp over plastic fuel tube
    • Filter/regulator to fuel tube by rotating filter/regulator in fuel tube until it is pointed towards front of tank
    • Line clamp to fuel line using special hose clamp pliers (number c-4124 or equivalent)
    • Filter/regulator (pressing by hand) into rubber grommet
  2. Rotate filter/regulator until pointed towards front of vehicle
  3. Install fuel tank.
  4. Check for fuel leaks.
Jul 11, 2009 | Dodge Durango Cars & Trucks
1999 jeep cherokee do you have to remove the fuel pump to replace
The combination Fuel Filter/Fuel Pressure Regulator is located on the fuel pump module. The fuel pump module is located on top of fuel tank.
The filter/regulator may be removed without removing fuel pump module although fuel tank must be removed.
REMOVAL
  1. Remove fuel tank. Refer to Fuel Tank Removal/Installation.
  2. Clean area around filter/regulator.
  3. Disconnect fuel line at filter/regulator. Refer to Quick-Connect Fittings for procedures.
  4. Remove retainer clamp from top of filter/regulator. Clamp snaps to tabs on pump module. Discard old clamp.
  5. Pry filter/regulator from top of pump module with 2 screwdrivers. Unit is snapped into module
  6. Discard gasket below filter/regulator.
    1. Before discarding filter/regulator assembly, inspect assembly to verify that O-rings are intact. If the smallest of the two O-rings can not be found on bottom of filter/regulator, it may be necessary to remove it from the fuel inlet passage in fuel pump module.
    INSTALLATION
    1. Clean recessed area in pump module where filter/regulator is to be installed.
    2. Obtain new filter/regulator (two new O-rings should already be installed)
    3. Apply a small amount of clean engine oil to O-rings. Do not install O-rings separately into fuel pump module. They will be damaged when installing filter/regulator.
    4. Install new gasket to top of fuel pump module.
    5. Press new filter/regulator into top of pump module until it snaps into position (a positive click must be heard or felt).
    6. The arrow molded into top of fuel pump module should be pointed towards front of vehicle (12 O'clock position).
    7. Rotate filter/regulator until fuel supply tube (fitting) is pointed towards front of vehicle (12 O'clock position).
    8. Install new retainer clamp (clamp snaps over top of filter/regulator and locks to flanges on pump module).
    9. Connect fuel line at filter/regulator. Refer to Quick-Connect Fittings for procedures.
    10. Install fuel tank. Refer to Fuel Tank Removal/Installation.
WARNING: THE FUEL SYSTEM IS UNDER CONSTANT FUEL PRESSURE EVEN WITH THE ENGINE OFF. THIS PRESSURE MUST BE RELEASED BEFORE SERVICING FUEL TANK .
Two different procedures may be used to drain fuel tank (lowering tank or using DRB scan tool).
The quickest draining procedure involves lowering the fuel tank.
As an alternative procedure, the electric fuel pump may be activated allowing tank to be drained at fuel rail connection. Refer to DRB scan tool for fuel pump activation procedures. Before disconnecting fuel line at fuel rail, release fuel pressure. Refer to the Fuel System Pressure Release Procedure for procedures. Attach end of special test hose tool number 6541, 6539, 6631 or 6923 at fuel rail disconnection (tool number will depend on model and/or engine application). Position opposite end of this hose tool to an approved gasoline draining station. Activate fuel pump and drain tank until empty.
If electric fuel pump is not operating, tank must be lowered for fuel draining. Refer to following procedures.
FUEL TANK REMOVAL
  1. Disconnect negative battery cable at battery.
  2. Release fuel system pressure. Refer to the Fuel System Pressure Release.
  3. Raise and support vehicle.
  4. If Equipped: Remove fuel tank skid plate.
  5. Remove 4 fuel hose shield mounting bolts and remove fuel hose shield from body.
    1. Remove fuel tank fill hose and vent hose clamps at fuel tank filler tube. Remove both hoses at fuel filler tube.
    2. Remove exhaust tailpipe heat shield mounting bolts and remove shield. CAUTION: To protect fuel tank from exhaust heat, this shield must reinstalled after tank installation.
    3. Place a hydraulic jack to bottom of fuel tank. WARNING: PLACE A SHOP TOWEL AROUND FUEL LINES TO CATCH ANY EXCESS FUEL .
      1. Disconnect fuel supply line from fuel extension line near front of fuel tank. Refer to Fuel Tubes/Lines/Hoses and Clamps. Also refer to Quick-Connect Fittings for procedures.
      2. Disconnect EVAP canister vent line near front of tank.
      3. Disconnect fuel pump module electrical connector (pigtail harness) near front of tank. Harness connector is clipped to body.
        1. Remove two fuel tank strap nuts. Position both tank support straps away from tank.
        2. Carefully lower right side of tank while feeding both fuel hoses through access hole in body. Fuel Tank Full And Not Drained Using DRB Scan Tool: To prevent fuel loss through hoses, keep left side of tank higher than right side while lowering. Do not allow hose openings to drop lower than top of tank.
        3. Continue lowering tank until clear of vehicle. Place tank on floor with left side (hose side) higher than right side
          1. Drain tank by removing fuel fill hose at tank. Fuel fill hose is largest of 2 hoses. Insert the drain hose (from an approved gasoline draining station) into hose opening. Drain tank until empty.
          2. If fuel pump module removal is necessary, refer to Fuel Pump Module Removal/installation for procedures.
          INSTALLATION
          1. If fuel pump module is being installed, refer to Fuel Pump Module Removal/installation for procedures.
          2. Install fuel fill/vent hoses to tank fittings. To prevent hose from kinking, rotate each hose until index mark on hose is aligned to index tang on fuel tank.
          3. Install hose clamps to hoses. Position clamps between index marks on each hose.
          4. Position fuel tank to hydraulic jack.
          5. Raise tank into position while guiding fuel fill and vent hoses into and through access hole in body.
          6. Continue raising tank until positioned to body.
          7. Attach two fuel tank mounting straps and mounting nuts. Tighten nuts to 10 Nm (90 in. lbs.) torque. Do not over tighten nuts.
          8. Install both fuel hoses to fuel fill tube. Tighten both retaining clamps.
          9. Position fuel hose shield to body. Install and tighten 4 mounting bolts.
          10. Connect fuel pump module pigtail harness electrical connector near front of tank.
          11. Connect fuel pump module supply line near front of tank. Refer to Quick-Connect Fittings for procedures.
          12. Connect EVAP hose near front of tank.
          13. Install exhaust tailpipe heat shield.
          1. Install fuel tank skid plate (if equipped).
          1. Lower vehicle and connect battery cable to battery.
Feb 08, 2009 | 1999 Jeep Cherokee
Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Logo
342 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
