Question about Kenmore Elite 45986 Front Load Washer
Water keeps filling up washer
My washer keeps getting water in it from the top left side of the washer door, it just keeps trickeling in and fills up about half way, then runs out the door....it looks like the place where the water comes from , but it wont stop....it sounds like i seal or gasket?
  • 4,070 Answers
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tube. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water
from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Posted on Oct 07, 2009
    Novelist:
  • 121 Answers
U have a bad water valve. thats the plastic piece behind the washer that the hoses hook upto. part roughly 39.99-89.99 labor 75-125.00 depending on were u live and who u use. if you decide to do it yourself i would say a 5 on a scale of 1-10 . turn water supply off, remove both hose.turn off power remove top panel 2screws in back and push panel back and off. remo 2 screws that hold water valve in place. remove wires from pld valve too new one. reassemble . hope this helps.
The water will not shut off completly it keeps trickeling in and will fill the drum after a week.
The reason that is happening is because the spring inside of the water inlet valve that is suppose to close it is weak and its not fully closing the valve so water seeps through it into the drum of the washer. To repair that the water inlet valve will need to be replaced.
If ya reply with the model number i will give ya the part number for that valve and instructions of how to replace it.
The model number can be found on a label inside of the door on the rim
GENE
Oct 10, 2011 | Kenmore 44042 Front Load Washer
Washer is filling very slow. Both hot and cold water are just trickeling in
turn off the water supply unscrew the filling pipes and look in the end they usually have a wire gauze filter check for blockages ie limescale
May 30, 2011 | Washing Machines
The cold water will not stop filling the washer. It continually runs to where it wants to over flow
remove the two screws one on each side of the top console,flip it up and on the left side you'll see a piece with a clear plastic hose line going to it,that's the water level switch or pressure switch that controls how much water fills into the washer.if the plastic line fell off or has a hole in it then this will happen or the pressure switch could be bad,you can take the hose off from the switch and blow into the line,no air should blow through it,if it does then there's a hole in the line,also you can blow into the hole on the switch very easy,you should hear a clicking sound but most likely the switch will be bad,they hardly ever go bad so check the clear line good.i think this is what you're talking about,if the water just keeps filling the washer even when it's off then you have a bad water valve on the back of the washer,dirt gets in the valve and it can't close all the way and water just keeps filling into the machine,if this is what's happening then shut down the house water valve until you can replace the water valve on the washer,let me know what you find.the part for the pressure switch is W10337780 and it's around 30 to 40 bucks,the part number for the water valve is
285805 and it's around 30 bucks
Nov 23, 2010 | Roper RAS8244KQ Top Load Washer
Washer continues to fill and overflows
start to fill the washer,then turn it off,if water still keeps filling you have a bad inlet water valve,if it stops then check the water level water hose from the water level switch to the side of the outer tub-mike
Jan 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water keeps filling the washer
If the washer keeps filling and overfilling then unplug the machine and see if the water still continues to come in. If this is the case, you have a bad water valve. If the washer just keeps filling and never gets to the top then your drain hose is shoved too far down into your house standpipe and must be pulled up and an air gap established.PART NUMBER 285805 @ 30.00 FOR WATER VALVE
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water will only trickle to fill ip washer. Is it
Most likely its the inlet hose or hose screen.
If water pressure is standard at all other areas in home secure 4 Hose washers at any lowes ace hardware or garden supply that sells garden hoses. Remove your hoses and place the ends in the basket and turn on the water. If you get a good flow out then look at the water valve inlet behind the washer. If its clean put on the new washers and retry it. Be sure to run the valve wide open a couple of times to flush out any mud or sediment before deciding the inlet is clear. sometimes the old galvanized pipes can be plugged up with rust. If the water is trickeling in and it is suppose to be on then it is not the solonid valve because its trickeling in not flowing. Let me know if this trick works and \please ratem me as high as you can. Thanks for using FIXYA and good luck.
Apr 06, 2009 | Washing Machines
Water leak upon filling at top/cabinet joint
Raise the washer top and inspect the water fill tube and the water level air hose.
You will need to set the timer to fill while you are watching for the water leak.
Feb 23, 2009 | Maytag SAV2555A Top Load Washer
Ge washer wont stop filling with water
The usual culprit for a washer that will not stop filling is the pressure switch. The switch is located inside the operator console behind the load size, or water level knob (this knob has different names based on the washer model). Before assuming the pressure is defective, however, inspect the pressure switch and ensure the small plastic air hose is still attached to it. It is common for this small air hose to come loose or develop small cracks or breaks. Without the hose installed, the switch cannot detect the appropriate pressure in the wash tub and will not shut off. The result: as washer that continually fills and will overflow. What appears to be a significant problem may only be a loose hose and few minutes of your time. Please inspect the switch, check the entire length of the hose for cracks and make sure the electrical connection(s) are intact and not corroded, then get back to me. I hope this helps you.
PS Make sure you UNPLUG the washer before servicing!
Dec 20, 2008 | GE WDSR2080D Top Load Washer
Washer fill with water when it is not on...
remove top 3 screws in rear of top panel..left rear corner water valve where hoses come in replace it not shutting off completely
May 19, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite top loader
first of all check to be sure the cold water vavle is opened all the way, then checked for a kinked hose. if both of those is ok there is a screen in the valve that catches trash in the water. remove the hose from the machine (and possibly from the supply valve )and check to make sure there are no obstructions.
if all that checks okyou have a bad water fill valve. you can order the valve from sears and it is very easy to replace.
good luck..
Dec 15, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
211 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
