Question about Garden
Spreading rates for a vicon fertiliser spreader.
Applying urea yesterday using a vicon fertiliser spreader and the urea went on way to heavy (went on at 100 kg /ha instead of 50 kg /ha). On the plastic adjuster that you turn where do you read it from what rate it is set at.
  • Anonymous Mar 14, 2014
    What setting to spread 50kg per acre with a Vicon RS C rota flow
  • 120 Answers
There should be a pointer and an indicator on the dial. Check to see if it obscured by dirt.
Posted on Oct 08, 2009
Need a agitator or reasonable facimily
Fixya does not sell agitators.
Oct 08, 2017 | Garden
True Temper Cyclone CB2000 granular fertiliser spreader settings
Because of the extreme caustic nature of salt, that substance can ruin any machine, regardless of the materials it is made of.
If you should try to spread it, it may work if the granule size matches the product the spreader is designed for, but immediately upon completion of your task, you would need to completely wash the spreader, getting any trace of salt off, and then if there are any metal parts, you would need to completely dry it.
That task could cause you to "forget about it".
God bless your efforts.
Apr 11, 2012 | Garden
I have a qualcast drop spreader but no instructions for setting spread rate
Usual to find this info on the fertilizer itself. It will show which number to set the spreader at.
Apr 06, 2012 | Garden
How do you check to see if calibration is exact
Usually the cheaper residential grade spreaders are not exact, nor do they need to be. The best way to tell how close it is, is to measure the area to be fertilized length and width. Multiply the two numbers (example: 30' x 40' = 1,200sq ft.) Adjust the spreader according to the reccomendations on the bag, and follow the directions exactly! Walk at a brisk pace around the perimeter once, and then back and forth spaceing your passes about 5' for rotory spreaders. Compare the amount of product you used, to the coverage chart on the bag. In my experience, most all lawn fertilizers are best spread at 50% to 60% open on your spreader setting adjuster. (example: If your spreader has settings of 1-15, I'd go with 8) Always follow the directions on the product container as best you can. Spreading a little too heavy, or a little too light is not going to hurt anything, so there is no reason to be concerned with exact calibration unless you are applying discriminative herbicides... Hope this helps!
Oct 08, 2011 | Scotts Company 589384 Scotts 5000 SQFT...
I have lost my instructions for my hand held spreader. The numbers on the side that control the outlet of whatever is in the spreader--do these indicate the number of pounds per 100 sq. ft?
Below is a list of spreader settings. You may want to call Scotts at 800-543-8873 and verify the product you are using is able to be used in a hand held spreader.
  • For fine grass seed (blue, rye, fescue) use setting 1
  • For coarser seed (tall fescue) use setting 2
  • For light fertilizer (Scotts fertilizers at a regular rate) use setting 3
  • For heavy fertilizer (Scotts fertilizers at a heavy setting) use setting 4
  • For pelletized fertilizer and ice melt products use setting 5
Hilary @Scotts
May 16, 2011 | Scotts 71133 Handgreen II Hand Held...
How do i calibrate the spreader
Your AccuGreen 3000 Drop Spreader was calibrated at the factory. However, a spreader's calibration may change or slip over time or during periods of heavy use.
You may check the calibration of your Scotts Accugreen 3000 by first adjusting your micrometer setting to 6. Turn the spreader over so that you are looking at the outside of the bottom of the hopper. Use your foot to hold down the trigger (if your trigger has a locking mechanism you can lock it in place prior to turning upside down). With the micrometer set at 6 and the trigger squeezed against the handle, the front edge of the projecting ridge on the shut-off bar should be aligned with the calibration line located on the 2nd or 3rd tooth from the center. Some of the older AccuGreen 3000 Drop Spreader spreader models do not have a raised ridge. On these spreaders, line the front edge of the shut off bar to the calibration line.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and raised ridge or front edge of the shut-off bar meet. If you have any difficulty checking or adjusting the calibration, contact us and we will be happy to help walk you through the adjustment.
Again, thank you for taking the time to contact us and for your interest in Scotts. Please feel free to call us at 1(800)5438873 anytime we may be of assistance.
Mar 03, 2011 | Scotts Company Scotts& Accugreeen 3000...
I buy Scotts fertilizer and use an earthway broadcast spreader.
add 10 - Scotts Turfbuilder spread at # 4 on a Scotts spreader should be on setting # 14 on an Earthway spreader.
Mar 28, 2010 | Earthway "Earthway" Medium Duty Commercial...
How to use Ace Green Turf Spreader
At the bottom of the spreader hopper is a gate, there should be a setting lock that allows the opening to move only so far. This may be at the handle controls but unlikely.
To be sure of your spreader pattern and rate, use the spreader on a parking lot to see the pattern, you can always sweep up the granules and reuse them! Walking speed is the biggest factor in spreading rates.... Opening is the next....
Jan 30, 2010 | ACE R Broadcast Spreader - Set of 2
Need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Jul 21, 2009 | Scotts Company Garden
Garden Logo
587 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
