On my lg tromm washing machine i keep getting IE message on it
    President:
  • 1,776 Answers
The "IE" code typically indicates a water fill problem. This code is generated if the correct water level is not reached within 8 minutes after water is supplied or if the preset water level is not reached within 25 minutes. The first thing to check is the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. Check the solenoids for continuity using a multimeter or ohmmeter. A lack of continuity will mean a bad solenoid and the valve assy will need replaced. I will attach a photo for reference. Please let me know if this is the problem. If it appears that the valve is not at fault, then I will attempt to provide further assistance. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 07, 2009
Have an error message ie readingon display. Any troubleshooting ideas
ie is the inlet error. Either your water is off or frozen or your valve is bad.
Feb 21, 2015 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
IE ERROR HAVE DONE WHAT REPAIR GUIDE SAID WITH NO RESULTS
this is inlet valve error message..its should replaced..might need to check harness may be damage
Sep 21, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have the LG TROMM WM2688HWM. Tried to wash a load and keep getting the error message: 'The door is open....'. I have held it closed, pushed it closed, opened and closed many times to no avai
the door actuator may be defective. if ur model has one? other wise sounds like the board is not communicating with the switch
by pass the door switch like this:
Feb 13, 2013 | LG WM2688HWM TROMM SteamWasher
My washer isn't drying anything very well. getting a oe message lg tromm wm2277hm
the OE message means that the machine has not fully drained out all the water. you can try to re set on drain or you may need a service call. hope this helps.
Oct 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
1E displayed in the Display panel of the LG front loading Washing Machine TROMM 6.6 KG
IE...Is a water inlet problem... clean the screens at the inlet hoses...
your fill vlave is not working,,, turn off the water supply and remove the clamps and undo the wires, could be just a plug in, may have to cut the wires get you a new one reinstall it with the flow going in the right direction and you will have water!!!!
Aug 30, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG TROMM reads a blinking LE message
motor locked...not and easy fix but if you want to give it a go let me know...onthejob
Jan 25, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
How old is the washer?
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg washing machine error code is ie
IE = inlet error. Washer has not detected enough water after 8 minute fill time. Check screen at inlet water valves where hoses connect to machine for blockage. Look for kinked hose(s). Make sure there is water supply reaching machine. If all OK, most likely next thing is the water valve itself.
Sep 02, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm 8/4 WD R8012
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
May 22, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
139 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
