Question about Kenmore Dryers
Kenmore 80 dryer runs and blows air but no heat
  • kklitzner Oct 07, 2009
    This is a gas dryer. Thanks for your help!
    President:
  • 1,776 Answers
If it's an electric dryer, then unplug the machine and check for a blown thermal fuse or a faulty heating element. The thermal fuse is about an inch long and is located inside the rear of the dryer, usually attached to or near the exhaust duct. The thermal fuse and heating element can be tested for continuity using a multimeter or ohmmeter. A lack of continuity will indicate a bad component. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 07, 2009
  • Bruce Canfield
    Bruce Canfield Oct 08, 2009
    If it is a gas dryer, then the first thing to check is to see if the ignitor is working. If the ignitor is working properly then it should glow visibly. If the ignitor is not glowing, then it can be checked using a multimeter or ohmmeter and testing continuity. A lack of continuity would indicate a faulty ignitor. If the ignitor seems to be operating properly, then the next possible cause would be faulty gas valve coils. These electrical coils are right above the gas valves and when energized these solenoids open the gas valves and permit gas flow to the burner. If faulty the gas valve do not open and the burner cannot light. It is recommended that if any coils are suspected of being faulty, that both (all) be replaced at the same time and they will most likely come from the parts supplier as a set. Really sorry for your trouble and I hope this helped. Best wishes.
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
Kenmore Electric Dryer model #11060812990, 80 Series - dryer is working but only blowing cool air.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 15, 2011 | Kenmore 659 Electric Dryer
I own a Kenmore dryer 80 series and the dryer works; however, its not blowing out hot air?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Kenmore Dryers
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Kenmore 80 series runs but dont blow hot air
Check your heating element. #1 cause for no heat. Easy to replace and ea VERY easy to break. Just for your own well being also make sure that gas pressure us correct
Feb 12, 2009 | Kenmore Dryers
KENMORE 80 SERIES NOT HEATING
you need to check the heating element and the thermal fuse in the back of the dryer, they should be their. do you have an ohme meter, if not barrow one or you can pick one up cheep and lowes or homedepo .
Dec 13, 2008 | Kenmore 659 Electric Dryer
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Dryers Logo
95 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
