Question about Christie LX45 Multimedia Projector
When unit powers up - nothing shows - menu rolls
When unit powers up - nothing shows - when I push menu on remote - it rolls through the screen like an old tv
  • 70 Answers
Resit your projector to factory default. if problem occur clean the entire projector. or change your projection bulb.
Posted on Oct 08, 2009
I accidentally changed the settings on my remote control using the on screen menu from dvd1 to dvd2
I'm not sure the question - perhaps your TV is set to the DVD2 input and it's not a DVD issue.
If so, using your TV remote, push the "input" button until you reach your desired input.
Apr 07, 2015 | Televison & Video
I have a iLO DVD recorder,it will turn on and show menu on front of unit but I can't get the menu to come on screen of TV.It is model #DVDR05/ZU.. You put a DVD into unit and push play on remote and it...
I have a DVDRo4 model so they may not be the same. I connect 3 wire RCA cables to the DVDR output and to TV 3wire RCA input. I set the TV chan to Aux. I set the DVDR souce button to disc. Hope this works on you unit 05
Nov 22, 2009 | iLO DVDR05 DVD Recorder
I want the code 7inch jensen indash dvd bypass code for vm 9312;9412,9512 I want the code 7inch" problem, and notify you when a new solution is offered. vm 9512
you must have the the remote to do this,
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv,the unit itself will have the blue screen but the additional tv's youhave plugged in will NOT, they will show the dvd menu. Thus you will beable to see the hidden menu on the additional screens after inputtingthe code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
Itmay take a few tries but you'll get it.
Best of Luck!
if you have questions email me mmaudio545@yahoo.com or post it on here
May 19, 2009 | Jensen VM9510 Car DVD Player
Do i need a remote to operate tv
once you have front panel in the tv and this one shows power channel +- volumen +- menu then your tv has to work with those ones and the remote is a second option to do the same. With this i mean you tv has to respond and at least show menu when you push that button " if no signal (cable DVD VCR) plug in"
Then if the tv is dead you should try to repair or sent it to repair. and then get the remote control and it can be universal too.
May 01, 2009 | Protron PLTV3250 32 in. LCD Television
Navigaiton bypass/hack for Jensen vm9512hd w nav101
buy a 3pin toggle switch
add a wire to the red wire (12v) in back of unit
do the same with the ground (black)
now install theses wires to the toggle switch (toggle switch has pictures of ground and positive pins)
install the brake wire to the pin that is empty on the toggle switch
power everything including the new installed switch and DVD should show
if not just switch the brake wire with the ground wire on the toggle switch
but the navigation should work with the unit while your driving...........this is the real trick to solve your problem
good luck
Feb 27, 2009 | Car Audio & Video
Blank Screen
Same Problem. I fixed mine with a baseball bat, hammer, and a cold beer. Lesson learned: NEVER BUY DELPHI AGAIN. NEVER..... Tell your friends. Delphi = POS
Aug 10, 2008 | Delphi NAV200 GPS Receiver
My GPS system is having seizures
The solution is listed on the garmin site but it is not clear
The problem is with the infra red remote reciever on the unit
Sometimes the sun acts like the remote is being pressed and that is when it shakes
the solution, and I hope you still have the unit cause there is nothing outthere like it.
Answer: from garmin site Normally this issue is caused by sunlight from certain angles hitting the Infrared (IR) port on the unit. This makes the unit react as if the remote control was communicating with it. This makes it switch in between screens just like if you were using the remote.
You can disable the remote IR port on your StreetPilot® 26xx unit by:
  1. Powering your unit ON
  2. Press the Menu button
  3. Touch Options
  4. Touch the General tab
  5. Press the Menu button
  6. Touch Disable remote
If you wish to use the remote again you can enable the remote IR port on your StreetPilot 26xx unit by:
  3. Touch Options
  6. Touch Enable remote
http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=2610+remote+off
Dec 26, 2007 | Garmin StreetPilot 2610 GPS Receiver
Rolling menu on screen
sounds like you have it in demo mode. In the menu will have it labeled demo on or off
Dec 09, 2007 | Zenith B32A24Z 32" TV
Hii
This is the way to do it without engaging the parking brake sequence, thus you're inputting the code blindly.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
Dec 04, 2007 | Jensen VM9510 Car DVD Player
Koss KS5190 Display mode stuck
I'm not ranked and I'm not a Guru, but I can solve this picture rolling when the problem is "the video was accidently changed from NTSC to PAL and you can't see what your doing to get it back". You will need the remote control unit. First, remove the disc from the tray. Now, turn the unit off with the power button. The tray will close by itself. After the display on the front of the unit goes out, turn the unit back on using the remote control. This will let you know the remote control unit is working. When the power comes back on and the display on the front of the DVD player says, "NO DISC", with the remote control and (very important) while pointing the remote at the player, (Remember to point the remote before pressing any buttons) press the "Down Arrow" button 3 times. This will take you to the "Display" box. Now, press the "Right Arrow" button 1 time. This will take you to the "TV Image"box. Now, press the "Down Arrow" 1 time, this will take you to the "PAL/NTSC" box. If you have done everything as I have tried to clearly lead you blindly to your destination. Press the "OK" button 1 time and the picture on the screen will stop rolling and change from black & white to color. You will have now changed your video output from PAL to NTSC. If you press "OK" again, it will start to roll again. If this did not take care of your problem, turn the player off and try it again.
The previous problem solvers were on the right track, but the track was rough and they just about derailed the train. Thanks to them, I had a track to follow. I had no other information, except what I found on "Fixya.com". MR. CD
Feb 03, 2007 | Koss KS5190 System
Christie LX45 Multimedia Projector Logo
112 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
