Question about Sylvania LC370SL8 37 in. LCD Television
Remove the base
How do I remove the base for mounting
  • Anonymous Dec 26, 2007
    I can't remove the base off the Sylvania TV either. It looks like there is a metal bracket within the tv that keeps the plastic base retained. I'm contemplating taking the whole thing apart. Can somebody help us? please =(
Tried this myself on 12/31/ worked. Happy Year!!
Posted on Jan 01, 2008
There are 4 philips head screws down near the base, 2 on each side. Remove those and the base will slide out.
Good Luck!
Posted on Dec 28, 2007
I need help removing the stand to my ASUS VH197D LED monitor so that i can attach my wall mount.
For the ASUS VH197D LED Monitor, turn it upside down so you are looking into the base of the stand. Squeeze the plastic tabs to unlock the base and pull. This will remove enough of the base to make it wall mounted and you can quickly attach the base if so desired. If you want to permanently remove the base and stand, remove the two screws that are now visible after the base is removed and pry out the plastic stand. This will break it off at the hidden screws. You will be left with a short metal stub that can be folded in.
Aug 01, 2011 | ASUS VH197D LCD TV
How do you remove the rear view mirror from mount.
Is the mount made of metal or plastic? In either case, it will be attached to a "base" that is glued to the windshield. A metal mount should have a tiny little screw in it that pins it against the base. Loosen this crew and the mount should slide upwards (towards roof) off the base. A plastic mount should have a tab that you can pull on and slide it off upwards....
Aug 10, 2009 | 1994 Buick Park Avenue
Viewsonic vg2021m base mount
Gently lay the nonitor, face down, on a table such that it will not be damaged while you remove the base. You will find a curved strip of plastic about 1 1/4 inch wide and 4 inches long. Near the center of this strip, you will find two parallel plastic ridges. These are clips that hold the base to the monitor support post. Squeeze these clips together to remove the base from the support post. I was able to squeeze the rear strip toward the rear of the base and ease the rear of the base off that clip and it came apart ok. It is a bit tricky, but doable. Good luck.
Dec 08, 2008 | ViewSonic VG2021m LCD Monitor
Need to remove the base so we can put the monitor on a wall mount
The base is removed by peeling off the feet pads to reveal screws that need to be loosed to reveal more of the base removal screws.
Dec 04, 2008 | X2Gen Computers & Internet
Removing the base of flat panel tv
You don't have to mess around with the screws on the bottom of the base.
There are 4 screws on the back of the Toshiba that are in line with the wall mounting screw holes.
Remove the 4 screws and the base falls off.
Nov 23, 2008 | Toshiba Televison & Video
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
How do i uninstall my old honeywell mercury thermostat
There are three parts to a T87F thermostat. Outer ring, thermostat body, and base mount. Remove the snap on ring that goes around the dial. Remove three screws from the thermostat that mount it to its base. Remove the thermostat. Disconnect and record what screws each wire attaches to. Remove the screws holding the base to the wall.
Jul 12, 2008 | Honeywell Heating & Cooling
Stand base removal
how do you remove the stand of lg 50pg30fd so it can be wall mounted
Jun 15, 2008 | Toshiba 42HP66 42 in. LCD Television
Akai PDP42Z5TA 42 in. Plasma base removal
If you ever get the base off, I'd like to buy one.
Apr 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Sylvania LC370SL8 37 in. LCD Television Logo
517 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
