Question about Frigidaire ATF6000ES Front Load Washer
Dishwasher not working does not drain water when i manually drain water(shopvac.) it works fine completes cycle but after is full of water again and will not work. have removed screens from bottom and cleaned but no help.
  • flybynet May 11, 2010
    is this a dishwasher or a clothes washer
  • 74 Answers
The pump that drains the water,the "askoll" pump has more than likely failed or could be disconnected.repair should be carried out by competent person.
Posted on Oct 07, 2009
SOURCE:
Why is my countertop dishwasher stuck in drain mode(s), and won't initiate or complete any wash cycle?
normally if a dishwasher fills then pauses it is trying to read the water level if it fills again it is trying get a reading from the pressure switch when it cant determine the water level it will drain to prevent it leaking, however you should get a error code for this kind of fault which makes me think it is the control board which is at fault by not being able to read the sensor rather than the sensor itself not working
Oct 08, 2014 | Dishwashers
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
Does not drain properly . It leaks through the door.
The leaks through the door problem is caused by an overfilled tub. Remember, these dishwashers aren't bath tubs. Those seals are only designed to keep water from splashing out, not for completely filling the dishwasher with water. These problems are both caused by the slow drain, and can usually be fixed quite easily by removing and cleaning the strainer screen and using a wet/dry shop vacuum to **** out the debris underneath. If your shopvac is powerful enough it will also clean out the water pump.
Replace the screen and try again.
Mar 05, 2010 | GE Nautilus 24" Built-in Dishwasher
Bosch dishwasher shx55m with bottom tub full of water
The dishwasher really shouldn't pass any particles near large enough to clog the drain hose. It sounds more like a mechanical issue. Check the circuit breaker to make sure it's not tripped. See if you can hit a cancel button or something to make it drain. Try to run another cycle. If the computer is stuck or acting funny, trying cutting the power for a while, holding down a stop/reset/cancel button, or running a cycle that you don't usually run. I had this kitchenaid that would randomly refuse the normal wash cycle, but would run fine when you ran rinse only or something, then regular wash and everything would be fine again too. If the line somehow is clogged, there's a good chance it's right where the hose connects to the disposal or drain pipe.
Feb 18, 2010 | Bosch Integra® 500 SHX55M05UC Built-in...
Dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Sep 13, 2009 | KitchenAid 24 in. KUDP01IL - Multiple...
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Not draining
check that the pump/filter is not blocked or that the drain hose is not "back filling from the sink waste piping -if it is plumbed in there.
Jun 06, 2007 | Maytag 24 in. MDB8951AWS Stainless Steel...
Whirlpool dishwasher DWF B00 W
get back to me and tell me if it drains or stays full of water and did you do work on the plumbing in the kitchin
May 13, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher won't drain all the way
After cleaning the air gap thingy my machine works fine again. This thing sits on the left lower back side of the machine (left when you are standing in front of the machine). It is a transparent plastic box with 3 hoses attached (drain hose from pump, drain hose to the outside and water). Inside the box is a black plastic float. If debris gets caught in there the float gets stuck.
Solution is to remove the part by pulling the 2 drain hoses out (there is a small black clip holding them in) and unclamp and remove the water hose. Rinse and shake the housing until the float moves freely again and reassemble.
Jul 31, 2006 | Siemens 24 in. SL84A305UC Built-in...
Frigidaire ATF6000ES Front Load Washer Logo
123 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
