Question about Toro Lawn Mower With Toro Power Tools
The mower is nine years old,when prime it just does not start,so i take and open the filter door and spray in starting fluid and it start and runs well nowwith it runing i prime it no change in runing . note i have rebuilt the carburetor and replace primer pusher,but not the door it goes in ( help)
I went to home depot and brougth a new one,any one want a nine year old mower
Posted on Oct 08, 2009
Pushmower won't start?
A few quick steps can help you diagnose the problem. Remove the air filter cover and air filter. Spray a shot of carb cleaner into the carb and try to start the mower. If the mower starts on the prime then you have a fuel issue. Be sure your fuel is fresh (less than a week old. Fuel is bad at 21 days old) and clean or rebuild the carb. If the mower wont start on the prime then it is an ignition or compression problem. Start by checking that the stop cable is pulling the bail off ground sufficiently.
Jul 27, 2014 | Toro Power Lawn Mower
My troy bilt lawn mower does not want to start like it loses priming. Can I reprime manually
if it has a bulb pump it about 20 times if not you could spray a little starting fluid in the air filter or take filter off and poor a little gas in the carb
Aug 03, 2013 | Troy Bilt 5.5hp Self Propelled Mower
How to prime a john deere 6415 after replacing fuel filters
disconnect the fuel lines after the filter and crank it. then hook the lines back up and crank it over. if its a diesel use some starting fluid and spray it into the intake to prime it.
Jul 12, 2011 | John Deere Garden
I bout a 22" push mover last year.The priming bulb on this has been torn and it is difficult to start it.It should not tear or get damaged so easily.Please help. Harjinder S Sabherwal
I agree the priming bulb should be more robust or somehow protected. You could replace the bulb, but soon have the same problem again. A simple work-around is to buy a can of spray instant-start (spray ether sold in auto parts stores). Spray this into the air filter each time you start the mower cold, thus avoiding the need to prime it.
Aug 27, 2010 | Mtd 22" Yard Machine Push Mower
I replaced the carburetor, spark plug, and put in new gasolone on a Toro Recycler (5 yrs. old) and it still won't start. The ignition is only one year old. Seems like I'm not getting any spark and the fuel...
Hi. Replace the air filter. Then use some starter fluid and an assistant. Spray some starter fluid into the air intake as you start it up and keep spraying so that it runs on the starter fluid for a few seconds until it really takes off. J.
If this does not do it then you will have to have the carburetor rebuilt as it has hardened gunk in it.
Aug 01, 2010 | Garden
Draper petrol lawnmower wont start
Check the fuel...most often stale fuel creates havoc...YOU MUST FLUSH THE TANK donot add to old crumby gas, YOU MUST clean out the carb(remove the fuel bowl and carb spray all the tiny openings,orifices, check the air filter, check the oil, Add NEW fresh fuel, and hit with a quick spray of starting fluid just prior to restarting...should run out well.
Jul 24, 2010 | Garden
What would cause mower to die after starting?
your carb. is gunked up. get a can of starter fluid and a helper. have the helper spray some starter fluid into the air intake to keep it running after it starts. Once it runs for a couple of minutes it will be ok. J.
Jun 27, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
My 675 will fire up a start and will immediatly quit. i have cleaned the spark plug and put in new gas.
it's still getting bad gas. take off air filter, prime with fresh gas, use an old spray can, and keep spraying while running until all old gas is used up in the carb
Jun 26, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
My craftsman riding mower model917.274641 won't start. I was using it and when I stopped to put a bagger on it wouldn't start. have replaced plug,gas and air filter. It backfires sometimes when turning...
First, take the air filter off and spray a shot of carb cleaner/ starting fluid in the carb. If it starts for a second and runs on the prime then its a fuel issue. Check fuel filter, fuel delivery, and carb.
Nov 23, 2009 | Craftsman Garden
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
134 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
